builtright3 Posted yesterday at 01:21 AM Share Posted yesterday at 01:21 AM Not sure why this post wont move out to the corner. Any help would be appreciated New Plan.zip Link to comment Share on other sites More sharing options...
JKEdmo Posted yesterday at 02:27 AM Share Posted yesterday at 02:27 AM 1 hour ago, builtright3 said: Not sure why this post wont move out to the corner. Any help would be appreciated New Plan.zip 4.95 MB · 4 downloads I believe it's because you had those balcony walls defined as railings with pony walls: I don't think pony walls are necessary here. The balcony lap siding half-height wall starts at the floor level. (The stucco wall is on floor below). So, I redefined the railing walls as solid rail style with newels/posts as post to beam. The post location seems to work now. Link to comment Share on other sites More sharing options...
Mark3D Posted yesterday at 02:53 AM Share Posted yesterday at 02:53 AM Also turn on attick walls there is one that messing with that intersection I found the problem went away when I deleted the attick walls if this is a suitable thing to do Link to comment Share on other sites More sharing options...
builtright3 Posted yesterday at 04:12 AM Author Share Posted yesterday at 04:12 AM Getting rid of those attic walls is what fixed it. Not sure why it generated the attic walls. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted 21 hours ago Share Posted 21 hours ago 2 hours ago, builtright3 said: Not sure why it generated the attic walls. You might check your Defaults/Walls/General Walls and uncheck "Auto Rebuild Attic Walls". I think this is checked by default but I find that it often creates more problems than it solves. Link to comment Share on other sites More sharing options...
builtright3 Posted 14 hours ago Author Share Posted 14 hours ago Good idea, Thank You Link to comment Share on other sites More sharing options...
builtright3 Posted 4 hours ago Author Share Posted 4 hours ago (edited) Hey guys, On this same project, I’m running into a situation where I’d like to build a room over an existing room that has a low ceiling. I understand how to physically build it, but I’m not sure what the best way is to make it work properly within Chief Architect. Any input or direction would be much appreciated. Just to clarify what I’m working on, I’m converting the garage into an ADU and adding a second story over the garage and part of the existing living room and dining room.Plan is still attached New Plan.zip Edited 4 hours ago by builtright3 Link to comment Share on other sites More sharing options...
