4hotshoez Posted April 20, 2015 Share Posted April 20, 2015 I have turned on the endpoint and midpoint snap settings several times, but they keep turning off. Are they saved in an anno-set or something? It would be nice to know so I can have what I need when I need it. Link to comment Share on other sites More sharing options...
dshall Posted April 20, 2015 Share Posted April 20, 2015 I have turned on the endpoint and midpoint snap settings several times, but they keep turning off. Are they saved in an anno-set or something? It would be nice to know so I can have what I need when I need it. I doubt it, set up a hot key to quickly turn the snaps on and off. Link to comment Share on other sites More sharing options...
4hotshoez Posted April 20, 2015 Author Share Posted April 20, 2015 I doubt it, set up a hot key to quickly turn the snaps on and off. I have this too, but the group of active snaps is changing some how. Link to comment Share on other sites More sharing options...
Doug_Park Posted April 20, 2015 Share Posted April 20, 2015 Check the hot keys assigned to snap toggles. It is possible you are hitting those hot keys without realizing that they are doing something. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 20, 2015 Share Posted April 20, 2015 Doug yep, that got me in the past Link to comment Share on other sites More sharing options...
4hotshoez Posted April 20, 2015 Author Share Posted April 20, 2015 Endpoint - 4 and midpoint - 5. I do not use these, but I will try to pay closer attention when they change. I have been moving around to several files, which may have default setting with endpoint and midpoint off. But it just seems more often than usual. Link to comment Share on other sites More sharing options...
