MickeyToo Posted April 21, 2015 Share Posted April 21, 2015 Looks like we may be dancing together on this one, Scott! Btw, Joe, with the label still attached, I selected the Lumber and changed it back to i-joist and immediately got the evaluation error. Link to comment Share on other sites More sharing options...
dshall Posted April 21, 2015 Share Posted April 21, 2015 Here are my snap settings: Joe, I tried those settings, still no go. Again, I had arrow pointing to a piece of lumber, label good, change lumber to tji and I lost label, turned back to lumber and correct label came back. My computer is not recognizing the tji's. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 Do you guys have Object Snaps turned on? When you grab the tip of the arrow and drag it onto the TJI it should show a snap indicator. There is nothing different with a TJI vs a piece of Lumber than the width. Object Snaps should over-ride the Grid Snaps. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 BTW, Switching from Lumber to TJI would of course disconnect. The edge of the Framing Member has moved so the connection is broken - you have to reconnect. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 You might also want to check your "Snap Distance". I have mine set to 12 pixels. Link to comment Share on other sites More sharing options...
dshall Posted April 21, 2015 Share Posted April 21, 2015 BTW, Switching from Lumber to TJI would of course disconnect. The edge of the Framing Member has moved so the connection is broken - you have to reconnect. That is not correct. If I have a label arrow attached to lumber, it reads correctly, if I change to TJI, I lose the correct label, I change back to lumber and I get correct label, I can go back and forth all day, never reconnecting arrow, and it will read correctly if I use lumber, it will not read correctly if I use a TJI. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 The only other thing I can think of that would cause this problem is that one of the arrows is pointing to something that's not a Framing Member. Try deleting one of the arrows and just connect the other one. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 21, 2015 Share Posted April 21, 2015 I wonder if the grid snaps are the problem with the arrows dis-connecting. I have mine set to 1/4" Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 Perry, My Grid Snaps are set to 1". That's the same for Scott's Plan. I did find that Scott had "Object Snaps" turned off in the Plan he posted. I turned them on and have no problem keeping a connection. Link to comment Share on other sites More sharing options...
dshall Posted April 21, 2015 Share Posted April 21, 2015 A very very short vid showing you what I am seeing. http://youtu.be/w70b9y7IgAk Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 21, 2015 Share Posted April 21, 2015 Perry, My Grid Snaps are set to 1". That's the same for Scott's Plan. I did find that Scott had "Object Snaps" turned off in the Plan he posted. I turned them on and have no problem keeping a connection. Thanks Joe, I'll try 1" and see if that makes a difference Link to comment Share on other sites More sharing options...
MickeyToo Posted April 21, 2015 Share Posted April 21, 2015 Joe, It does not appear to be a connection issue b/c with the Framing Line Label yielding an Evaluation Error (connected to the i-joist), if I open the Text Object and add the ObjectProperties Macro, it yields all of the available parameters. I have seen a number of "quirky" issues with X7, so who knows? When I have a chance I will try it X6 to see if it makes a difference. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 Scott, Move the Arrowhead to the far side of the Framing Member. See what happens then. It doesn't make any difference on my system (I can switch back and forth between Lumber and I-Joists all day and I get the correct text) but who knows - maybe the arrowhead just needs to be in a slightly different location. IAE, I would really like to know if when it fails on your system - can you connect the arrow to the TJI and get it to work right? Link to comment Share on other sites More sharing options...
dshall Posted April 21, 2015 Share Posted April 21, 2015 Joe, I have tried both sides, I have tried voodoo chants, I have tried the rain dance, I have found nothing that works. Even if I found something that works, should it be this difficult? Mickey and I are both having problems, I cannot explain it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 Scott, I can't explain it. It works on my system consistently even using your Plan. Are both of you on Macs? Have you upgraded to the latest version of X7? Something is different and I just don't know what. Link to comment Share on other sites More sharing options...
MickeyToo Posted April 21, 2015 Share Posted April 21, 2015 Scott is on a Mac, and I am on Windows machine (7). I have the latest Chief update installed. Tried to run it in X6, but as you probably know that is not possible. Be interested to know if any other users viewing this thread have had the same problem. Thanks for taking the time to try to resolve it! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 21, 2015 Share Posted April 21, 2015 When I change to I-joists ,I also get evaluation error Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 I uploaded a new version of the CAD Block. It's named Framing Member(s). See if it works for you. Note that it has a slightly different Macro. Oops!!!! That one will definitely not work. This one will!!!! Framing Member(s).calibz Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 21, 2015 Share Posted April 21, 2015 Havent tried the new one yet but I have noticed for me if the arrow is at an angle it dis-connects easier, try to square it up and try. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 21, 2015 Share Posted April 21, 2015 Perry, If the new one doesn't work then I'll post the macro and you can add it directly to a RTB. It seems that sometimes when importing a Library Object that has a macro it might not replace a macro of the same name. IAE, I have determined that it really isn't so much a connection problem as it was the fact that the macro was wrong. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 22, 2015 Share Posted April 22, 2015 Direct to the RTB works good, thanks Link to comment Share on other sites More sharing options...
MickeyToo Posted April 22, 2015 Share Posted April 22, 2015 Joe, got the same results with the new library object. What exactly is RTB? And while you are at it, what about IAE? I am not up to speed on all of these new ways of communicating. Thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 22, 2015 Share Posted April 22, 2015 Mick, RTB = Rich Text Box IAE = In Any Event Here's the macro Framing Member(s).zip Link to comment Share on other sites More sharing options...
MickeyToo Posted April 22, 2015 Share Posted April 22, 2015 Thanks, Joe. Link to comment Share on other sites More sharing options...
MickeyToo Posted April 22, 2015 Share Posted April 22, 2015 Joe, works like a charm. Thanks much! Link to comment Share on other sites More sharing options...
