JKEdmo Posted 14 hours ago Share Posted 14 hours ago Hello, I'm doing some quick and dirty elevation cleanup with CAD boxes and I'd like to I have my stone fill pattern "Mill Creek Country Squire" available as a fill pattern for my polyline box. In other words, I'd like 2) CAD fill pattern match the 1) material pattern: I'm confused that the material pattern is not available in the polyline box fill pattern pull-down list. How do I make available? Are these material patterns different from CAD patterns? Thanks once again, Jim Link to comment Share on other sites More sharing options...
Solution robdyck Posted 14 hours ago Solution Share Posted 14 hours ago Add the Material to your library. From the library, right click the material and select edit pattern. Marquee select the highlighted area and press ctrl-c. Back in plan view, go to CAD>Patterns>Create New Pattern. Name it and make it the same size (32"x32"). When the window opens, Press ctrl-alt-v (paste-in-place). Close the window and choose Save. Link to comment Share on other sites More sharing options...
robdyck Posted 14 hours ago Share Posted 14 hours ago Oh, and don't forget to check the pattern scale...it's 1.5 for your cad polylines. Looks like it works. Link to comment Share on other sites More sharing options...
JKEdmo Posted 13 hours ago Author Share Posted 13 hours ago Robert, Super cool! I learned something today thanks to you. It seems the process is sort of convoluted... Do you think it's worth a suggestion to Chief to allow these patterns to be automatically available if the materials are already part of the project file? If so, I'll make the suggestion. Seems like material and cad patterns are pretty much the same animal unless I'm missing something fundamental. Jim Link to comment Share on other sites More sharing options...
Chrisb222 Posted 40 minutes ago Share Posted 40 minutes ago 13 hours ago, robdyck said: Add the Material to your library. From the library, right click the material and select edit pattern. Marquee select the highlighted area and press ctrl-c. Back in plan view, go to CAD>Patterns>Create New Pattern. Name it and make it the same size (32"x32"). When the window opens, Press ctrl-alt-v (paste-in-place). Close the window and choose Save. Saved that to my tips and tricks file, thanks Robert. Link to comment Share on other sites More sharing options...
PitMan71 Posted 30 minutes ago Share Posted 30 minutes ago 9 minutes ago, Chrisb222 said: Saved that to my tips and tricks file, thanks Robert. Me too. And thanks @Chrisb222for the "Tips and tricks file" tip. Link to comment Share on other sites More sharing options...
