Wall top and bottom inconsistancies.
Doug_N
Its because of your "open to below" space for the stairwell. Why it's only affecting that side is beyond me. The notch is where the sill plate is on top of the stem wall. You can clean it up by turning off the brick extension on your brick wall above. Then you will have a bit of manual wall cleanup you will need to do in the space where the notch is. If you want a brick ledge you might want to consider doing a ponywall for the basement with 8" concrete at the bottom and a brick concrete wall at the top where the brick face lines up with the brick face above. Constructionwise I don't know how that would work since I typically use 12" poured walls for my foundation. Eitherway its an idea maybe you didn't think of yet.
45 minutes ago, Doug_N said:
Shane is right, it appears to be caused by the open below room. Not sure what's going on but the easiest way I found to fix the brick was create a 0.1" width "room" next the the exterior wall, and turn off the room label:
1968033045_Screenshot2026-02-01at4_07_13PM.thumb.png.ba71a50344a7c877ebf93ef5e8e18063.png
