GeneDavis Posted 14 hours ago Share Posted 14 hours ago I used solids, blocked, to create the iron countertop brackets seen here. I want to display them in plan view using dashed lines, just as the under-counter base cabs and appliance display. See here. They are in their own layer, "Cabinets, countertops, brackets" and that layer is assigned dashed line. Since they are blocked, I changed the layer for Architectural Blocks to have the preferred line type and thickness. But none of this is producing the plan view I need. Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted 13 hours ago Solution Share Posted 13 hours ago 49 minutes ago, GeneDavis said: I used solids, blocked, to create the iron countertop brackets seen here If they are simply blocked solids, they're probably still getting their line style info from the 3D Solids layer. Try changing it there. Or you could make them a symbol then the layer settings are more straightforward. Link to comment Share on other sites More sharing options...
GeneDavis Posted 13 hours ago Author Share Posted 13 hours ago Thanks, @Chrisb222. That was it. 1 Link to comment Share on other sites More sharing options...
joey_martin Posted 12 hours ago Share Posted 12 hours ago I put them on the same layer as the base cabinets. Link to comment Share on other sites More sharing options...
