X16 upgrade to X17
PitMan71
Go to solution Solved by mtldesigns,
Anybody use X16 and X17 at the same time for different projects? Or did you upgrade and move everything to the new version? I feel it would be best to finish X16 projects in X16 and start new projects in X17. Anyway, I am concerned that X16 projects near completion in X17 might have some unknown adjustments if I import them.
Thanks in advance.
  • Solution
@PitMan71
The projects I was real close to being competed in X16, I finished in 16.  I did have a couple others started in 16, but then saved in 17, and I have not seen any issues thus far.
That bears the question.. how many versions should we keep on our PCs?  I have 12-17.
