Roof surface hanging past fascia
hyldahldesign
For some reason, the surface of my roof is hanging past the fascia by 3.5" and I can't figure out why or how to fix it. I guess it's actually that the fascia and subfascia are stopping short of the end of the roof by 3.5" as it seems as though the roof surface is hanging past the baseline the correct amount. What setting do I need to fix to get the fascia to build in the proper spot so there isn't so much roof surface overhang?
3 hours ago, Chrisb222 said:
Your Shadow Board settings are all bass-ackwards. They should be set like this (Gable Only is a preference, not required):
981764403_Screenshot2025-12-04at11_58_46AM.thumb.png.c90b8cfd7dc57c004a33fea853de7369.png
Unfortunately I had to turn Auto Roofs back on to get it to correct the issue.
Oh my gosh, thank you! That solved it. I don't know that I ever would've figured that one out! Not sure how or why those shadow boards ended up so backwards.
