Hatrak Posted April 10, 2015 Share Posted April 10, 2015 Anyone know an easier way to create this style roof return than to manually draw and edit?? 1 Link to comment Share on other sites More sharing options...
MickeyToo Posted April 10, 2015 Share Posted April 10, 2015 Have you seen this Chief Knowledge Base article "Creating Automatic Roof Returns?" http://www.chiefarchitect.com/support/article/KB-00647/34/Chief-Architect/Roofs/Creating-Automatic-Roof-Returns.html Link to comment Share on other sites More sharing options...
evergreen Posted April 10, 2015 Share Posted April 10, 2015 I don't believe so (at least not in the exact way its shown in your attached image). Create one, then copy it. That might be the better way to go. Link to comment Share on other sites More sharing options...
Hatrak Posted April 10, 2015 Author Share Posted April 10, 2015 Yup. I missed the "extend" button. I mistakenly thot it refered to the lateral lenght rather than outward extention. Makes it a lot easier. Thanks. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 10, 2015 Share Posted April 10, 2015 Am I missing something? ,cos that's what the Auto Roof return settings are for eg the pic below is a 42" Return with a 12" extension and hip roof (and ridgecaps and gutters turned on) why would you do it manually? Edit ...I see you found the answer while I was doing the test plan above Link to comment Share on other sites More sharing options...
evergreen Posted April 10, 2015 Share Posted April 10, 2015 hmmm, missed that, never used it, but nice feature. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted April 11, 2015 Share Posted April 11, 2015 If only we could adjust the pitch...............maybe X8 Link to comment Share on other sites More sharing options...
Hatrak Posted April 11, 2015 Author Share Posted April 11, 2015 Don't think that would work, Larry. Because it extends the main roof, it has to be the same pitch. What's a bit misleading, is that in both the article mentioned above, as well as what is shown in the X1 reference manual I have, only three examples are shown, while excluding the extended one. I just natually thot that was the only automatically way it could be done, so just glossed over the "extension" mention. Silly me! Link to comment Share on other sites More sharing options...
MickeyToo Posted April 11, 2015 Share Posted April 11, 2015 David, it is not you. While the documentation in Chief is generally pretty good, there are situations where it could be made much better. This is one of those cases. I usually hit the Help button at the bottom of the dialog box if I am not certain about what a setting signifies, but even here the explanation seems to be somewhat lacking. And so yes, they could have easily included a picture of one of the three return styles using the Extend feature. Another case where a picture is worth a thousand words Link to comment Share on other sites More sharing options...
