How to eliminate ceiling lines coming through exterior wall
GeneDavis
One end of a simple gabled-roof house has some kind of fault, in that the ceiling lines "come through" and show in elevation.  See the pic.  The gable elevation at the opposite end has no such lines showing in elevation.
Here is the difference.  Inside, at the gable with the lines showing, there are manually drawn ceiling planes.  Those 4:12 lines do not show in the elevation view.  What is showing is the ceiling lines in room definition, with the central area ceiling up high so the stacked window is all on floor 1.  The opposite elevation has its rooms inside all at 9/0 and there are no manually drawn ceiling planes.
