Evolution Posted September 5, 2025 Share Posted September 5, 2025 (edited) (edit) I am now also missing my lower tool bar that has always been at the bottom of the drawing sheet that has the open object, replicate, parallel, center, point to point, convert polyline etc., tools. I attempted the restore tool bars, import tool bars, and so forth error messages with others. Went to the help file read all the various repair / fix options but so far have not been able to restore that one particular tool bar. I especially need the transform replicate, also the convert polyline tools back. I am not sure what could have happened like so many of Chiefers state when encountering the same issue. I was able to find the answer on the forum either. Currently I am re-installing my CA-12 to see if that does any good. I was able to move forward with the subdivision from my previous post regarding proper scaling. Got that done. Submitted the subdivision for review and the Zoning Planning Reviewer provided comments which I need to address on this next submission. I think I can handle all but a couple. 1. He wants me to add a "Civil" scale (Map Scale with Bar Graph) to verify lot widths, road and block lengths. I thought a cad block / symbol (if I can figure out how to get it to proper scale) any thoughts on this? 2. The scale has to be 1" = 100'-0". I know that scale is too large to print to a 24"X36" (required for submission) and if I rotate it to horizontal (to accommodate the scale) the plan is wonky, so looks like I have to cut the plan at a match point and include it on a second sheet. I need to keep it simple (for me) but since the work has to be done on the drawing (not the layout sheet) and whatever is drawn on the drawing sheet sent to the layout sheet, what's the best way to do this (if there's a trick) so that everything I draw on the drawing sheet doesn't send over in multiples to the layout or if by choosing a different page for example, may SD on layout page SK-4 and remaining SD on SK-5, then just drag the handle of the transfer until only what is needed, is left to show on the layout page. Does that make any sense? REVISED W. HORNES CHURCH RD SUBDIVISION.plan Edited September 5, 2025 by Evolution added question Link to comment Share on other sites More sharing options...
JiAngelo Posted September 5, 2025 Share Posted September 5, 2025 (edited) For #2, send the full plan @ 1'=100' to SK4 On SK4 select the oversized layout box and copy in place. Select one of the boxes and move it right or left until both boxes are side by side. Select bottom of left box and crop up to midpoint. Select top of right box amd crop down to midpoint. Keep left on SK4 move right to SK5. Now whatever you draw will appear on the proper page. To align the boxes on each page. Set the box on SK4 where you want it. Draw a control line starting at the upper right corner off at a 45 degree angle. Copy and paste in place to SK5. Move box on SK5 to match upper right corner with starting point of your line. (Draw a temp line on your plan so you know which items are appearing on SK4 vs SK5, and this will also let you know if you need to adjust the matchpoint location.) For #1, open up a cad detail box. Draw your "map scale with bar graph" to real world dimensions 1" = 25', 50', 75', 100', 200' Send this to each layout page at 1"=100' and it should match and serve as a map scale for your subdivision layouts. Edited September 5, 2025 by JiAngelo Spelling Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2025 Share Posted September 5, 2025 Regarding the toolbar problem, have you tried "reset side windows" in the preferences? I think the edit toolbar is controlled by the side windows setting but you might need to use the "reset toolbars" button too. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 6, 2025 Share Posted September 6, 2025 (edited) On 9/5/2025 at 6:15 AM, Evolution said: am now also missing my lower tool bar that has always been at the bottom of the drawing sheet that has the open object, replicate, parallel, center, point to point, convert polyline etc., tools I lose the bottom tool bar when the window changes size. A double click on the CA window title bar brings it back to properly fill the screen. This typically happens when my computer resumes from sleep mode///for some unknown reason Edited September 6, 2025 by SHCanada2 Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 6, 2025 Share Posted September 6, 2025 On 9/5/2025 at 6:15 AM, Evolution said: 1. He wants me to add a "Civil" scale (Map Scale with Bar Graph) to verify lot widths, road and block lengths. I thought a cad block / symbol (if I can figure out how to get it to proper scale) any thoughts on this? I've seen this posted on the forum in the past, but I do not remember the answer (other than of course create your own). you may wish to search the forum on this one for a predone one, or scale a predone one Link to comment Share on other sites More sharing options...
Solution SHCanada2 Posted September 6, 2025 Solution Share Posted September 6, 2025 On 9/5/2025 at 6:15 AM, Evolution said: or if by choosing a different page for example, may SD on layout page SK-4 and remaining SD on SK-5, then just drag the handle of the transfer until only what is needed, is left to show on the layout page Thats what I would do, split it up across pages, by sending it twice to layout, on different pages, and cropping the layout box differently on the pages to reflect the portions of the block plan Link to comment Share on other sites More sharing options...
