Medeek Posted June 23 Author Share Posted June 23 Version 4.6.6 - 06.23.2026 Added a Curved Segment option/tool for railing assemblies. Added a Spline Railing tool into the Stair Toolbar. Spline Railings enabled using a Centripetal Catmull-Rom spline algorithm with user selected start and end tangency points Link to comment Share on other sites More sharing options...
Medeek Posted June 24 Author Share Posted June 24 Link to comment Share on other sites More sharing options...
Medeek Posted June 24 Author Share Posted June 24 As I've stated in the recent tutorial the regen time of this spline railings can suffer because of the large poly handrails and/or shoerails. In the next update I will be introducing and option where the user can toggle a "split" option for both the handrail and shoerail. This will split those two curved solids into separate segments (at the intermediate posts). For larger spline railing assemblies my internal testing has shown an almost 100% performance (draw, edit, regen). These two parameters will be found in the intermediate post sub-menu, see image below: Link to comment Share on other sites More sharing options...
Medeek Posted June 26 Author Share Posted June 26 Version 4.6.7 - 06.25.2026 Added a “GLASS” baluster option for curved and straight rail assemblies. Added a “CABLE” baluster option for curved and straight rail assemblies. Link to comment Share on other sites More sharing options...
Medeek Posted June 27 Author Share Posted June 27 Version 4.6.7b - 06.26.2026 - Enabled deck railing for spline railing assemblies. - Added a "GLASS" baluster option for spline railing assemblies. - Added a "CABLE" baluster option for spline railing assemblies. Link to comment Share on other sites More sharing options...
Medeek Posted June 29 Author Share Posted June 29 **Tutorial 91**: Curved Stairs II - (17:37 min.) https://youtu.be/8ZNcJTEPSvA Link to comment Share on other sites More sharing options...
Medeek Posted July 2 Author Share Posted July 2 The custom wall "draw" tool is going to be a little bit different from the existing wall tools. Currently I have it so that can select a face (grouped or ungrouped). The face has to be vertical, in more precise terms this means the face normal vector must be perpendicular to the Z axis. Also note that as you hover over the face the nearest vertex is highlighted with the light green circle: This indicates where the "origin" or start point of the wall will be drawn from. Once you select the face, the tool then goes to phase 2, which allows you to project along the face in one of two directions. This will determine which side is the interior or exterior of the wall: The thick blue line indicates the ray or vector that is being used to determine which way the wall is facing, also the 3D wireframe indicates the wall's general envelope or geometry. Link to comment Share on other sites More sharing options...
Medeek Posted July 6 Author Share Posted July 6 Testing garage doors and doors: Link to comment Share on other sites More sharing options...
Medeek Posted July 7 Author Share Posted July 7 Custom or “complex” walls are really no different than complex roofs or floors. They are defined by an array of points. I was just going to adapt my current “Outline Edit” method for Custom walls but I felt like it was time for a bit of an upgrade. I’m hoping people will find this new tool a bit more intuitive. After I fully test it I may incorporate the same logic/tool into the other plugins for the following: Complex Roofs, Floors, Slab-on-Grad foundations, Polyline Stemwalls and Railings. Link to comment Share on other sites More sharing options...
Medeek Posted July 10 Author Share Posted July 10 Today we are testing sheathing, cladding, gypsum and rainscreens: Yesterday we tested tee intersections. Link to comment Share on other sites More sharing options...
Medeek Posted July 16 Author Share Posted July 16 (edited) First look at wainscot applied to Custom walls. Edited July 16 by Medeek Link to comment Share on other sites More sharing options...
Medeek Posted July 16 Author Share Posted July 16 First look at quoins applied to Custom walls. Link to comment Share on other sites More sharing options...
Medeek Posted July 17 Author Share Posted July 17 **Version 4.6.9** - 07.16.2026 Enabled advanced options for Custom walls. Link to comment Share on other sites More sharing options...
Medeek Posted July 19 Author Share Posted July 19 (edited) **Tutorial 92: Custom Walls** - (14:47 min) Edited Wednesday at 07:46 PM by Medeek Link to comment Share on other sites More sharing options...
Medeek Posted July 20 Author Share Posted July 20 **Version 4.7.0b** - 07.20.2026 - Added a floating grid to the Custom wall draw and profile edit tool when the "Grid Snap" option is toggled on. Link to comment Share on other sites More sharing options...
Medeek Posted July 21 Author Share Posted July 21 Version 2.1.5 - 07.20.2026 - Added a SOG "profile" edit tool within the context menu for polygon slab-on-grade assemblies. - Added a "Grid Snap" option with hotkey (End key) into the SOG profile edit tool. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted July 24 Share Posted July 24 Hey Nathan, I want to use your Foundation SU extension to create a series of Foundation Details. When I start with crawlspaces, is there a correct way to only create a short 4' to 8' piece of linear wall with all the rebar, etc, instead of having to create a full rectangular crawlspace.....then having to explode and cut it? I know this seems odd, but it would be really cool if I could trace out a six-foot linear line and then have your extension draw that item with all the metal and choices that I had selected. You might already have this feature, but if not, imagine using your extensions to create real-world 3D details. If you want to discuss this more in an offline manner, we can do that too. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted July 24 Share Posted July 24 Nevermind brother, I figured it out. All I had to do was go to the create crawlspace by polygon and once I click the first point and start dragging the wall, I just type in the length I want and press enter twice and it just makes a segment of the wall with all the contents inside of it. X-ray becomes very cool at that point. 1 Link to comment Share on other sites More sharing options...
Medeek Posted Monday at 09:49 PM Author Share Posted Monday at 09:49 PM The API connector/bridge seems to be working, just need to do some more testing and also add the roof: 1 Link to comment Share on other sites More sharing options...
Medeek Posted Tuesday at 07:26 PM Author Share Posted Tuesday at 07:26 PM The first attempt was a bit crude in my opinion. After some fiddling with fonts and dimensions things look a bit more presentable: Link to comment Share on other sites More sharing options...
Medeek Posted Wednesday at 11:43 AM Author Share Posted Wednesday at 11:43 AM I'm trying to get it to slow down so you can see the step by step build process. Link to comment Share on other sites More sharing options...
Medeek Posted Wednesday at 07:43 PM Author Share Posted Wednesday at 07:43 PM (edited) Tutorial 7 - Garage Builder (16:14 min.) Edited Wednesday at 07:45 PM by Medeek 1 Link to comment Share on other sites More sharing options...
