Medeek Posted May 8 Author Share Posted May 8 I spent the better part of today trying to figure out ways to make the boolean subtraction more efficient. In the end my best solution was to create a square “cutter” in place of the actual (ornate) post which does significantly help. Now I just need to do a few more checks and throw the kitchen sink at this thing: Link to comment Share on other sites More sharing options...
Medeek Posted May 8 Author Share Posted May 8 **Tutorial 86**: Stair Railing https://youtu.be/TqZTTJ2kkYE Link to comment Share on other sites More sharing options...
Medeek Posted May 11 Author Share Posted May 11 I’ve been pondering how to control the truss layout of these complex roofs and after much thought and sleeping on the problem for a night I’ve come to the conclusion that for all but the simplest roof types (gable or half hip both ends on a rectangular footprint) there needs to be user specified girder trusses. Even the simplest hip roof (rectangular, hip both ends) needs two girder trusses. The algorithm should be smart enough to detect the layout in such a simple case but even so the setback of those girder trusses will have to be user controlled. With my existing hip set tools this is provided as a simple numeric value since the location and orientation of the hip girders is already determined. When you move to complex roofs the location of the girders becomes completely open ended. In other words we have too many degrees of freedom to confidently compute the solution. You can’t solve a multi-variable math problem if you have more variables than you have constraints or equations. That is the nature of this beast. My thinking is this: 1.) The user creates the perimeter or outline of the complex truss roof just as one currently does with the complex rafter module. The general roof shape and secondary features are generated (ie. sub-fascia, sheathing, cladding, gutter, soffit and fascia etc…), however the actual truss framing is not generated with this initial creation step. 2.) Next, the user clicks the girder truss creation tool which allows one to add in specific girder trusses between any two points within the roof outline (layer). The algorithm will require that the two endpoints of the new girder either terminate on the perimeter or along the length of an existing girder. Obviously the new girder cannot have both of its points on a perimeter edge or another girder, so that check will be built in. An HTML dialog box will allow the user to set a number of properties of the girder (ie. 2-ply, top chord depth, bottom chord depth, truss configuration, panel number for hip girders etc…) 3.) Once the girders are set then a context menu option will allow the user to attempt to generate the actual truss framing. If the girder layout is inconsistent, or illogical it will fail and display the applicable warning to the user. I’m still feeling this one out a bit so there may be an additional step where the user determines the rotation of the trusses in each zone created by the girder trusses. I think I can make this work but only time and some extensively testing will tell. I think the concept is fundamentally sound but as I’ve learned in the past with other programming problems, the devil is in the details 1 Link to comment Share on other sites More sharing options...
Medeek Posted May 12 Author Share Posted May 12 Here is a simple schematic of a slightly more convoluted roof to try and understand the methodology a bit better: The two girders in the center of the structure could probably be combined into one larger girder, but maybe it is better to distribute the loads across to trusses instead of one. The shaded areas are the valley sets or overframing required to fill in the voids. This design requires 10 main girders and 5 cross girders. Notice how there is a hip truss at each outside corner and a half valley set at each inside corner. When to inside corners are symmetric we end up with a full valley set. Based on these patterns that are emerging I might be able to auto place the girders or at least provide an initial placement which then can be further refined by the user. Link to comment Share on other sites More sharing options...
Medeek Posted May 22 Author Share Posted May 22 **Version 4.5.4** - 05.22.2026 - Added an option for a top and a bottom baluster shoe. - The top baluster shoe can be controlled with the additional "shoe height" parameter, which in turn allows for baluster collars. - Added the shoerail offset parameter to vertically offset the shoerail. - Fixed a bug in the railing edit menu with metric units. 1 Link to comment Share on other sites More sharing options...
Medeek Posted May 25 Author Share Posted May 25 **Version 4.5.6** - 05.25.2026 - Enabled presets for beams. - Enabled presets for in-wall columns. Link to comment Share on other sites More sharing options...
Medeek Posted May 26 Author Share Posted May 26 Version 4.5.6b - 05.25.2026 - Enabled presets for stairs. Link to comment Share on other sites More sharing options...
Medeek Posted May 27 Author Share Posted May 27 Version 4.5.7 - 05.26.2026 - Enabled presets for posts. - Added the following L.J. Smith handrail profiles: 684, LJ6011, LJ6A10. For those interested I am pulling all of my handrail geometry from LJ Smith's webpage at the following link: https://www.ljsmith.com/handrails Link to comment Share on other sites More sharing options...
Medeek Posted May 31 Author Share Posted May 31 **Version 4.5.9** - 05.31.2026 - Added two new parameters for elliptical curved stairs into the draw and edit menus: Eccentricity, Clocking. - Enabled treads, risers and framing (primitive) for curved (elliptical) stairs. Link to comment Share on other sites More sharing options...
Medeek Posted June 1 Author Share Posted June 1 Link to comment Share on other sites More sharing options...
Medeek Posted Wednesday at 10:55 AM Author Share Posted Wednesday at 10:55 AM I've been working on close stringers for curved stair cases. The circular variety is pretty much figured out but the elliptical variety still needs an instantaneous adjustment to the stringer depth since the pitch angle of the stairs (slope) is constantly changing. The geometry of a 0.9 eccentric ellipse shows off this distortion quite well. I will hit it again tomorrow and see if I can't figure out a more accurate algorithm for these stringers. Sometimes I enjoy a good challenge, but this one has certainly had me scratching my head a few times already. Link to comment Share on other sites More sharing options...
Medeek Posted Thursday at 04:51 AM Author Share Posted Thursday at 04:51 AM Medeek Wall: Version 4.6.0 - 06.03.2026 - Added a curved “closed” stair option into the stair module. - Enabled closed stringers for curved (elliptical and circular) stairs. - Added a separate layer for stair stringers. Link to comment Share on other sites More sharing options...
Medeek Posted Thursday at 09:14 AM Author Share Posted Thursday at 09:14 AM (edited) Edited Thursday at 09:15 AM by Medeek Link to comment Share on other sites More sharing options...
Medeek Posted Friday at 12:59 AM Author Share Posted Friday at 12:59 AM After mucking around with the follow me API call and a few other algorithms I decided to strike out on my own yesterday, and with a little help from ChatGPT and quite a few iterations I was able to finally generate the closed helical stringers. Using the same principle and by rotating the profile I am now able to generate a similar mesh for the handrails. These are high poly but it does look great and we now have eliminated the twisting issue that I had never resolved using other methods. So a major step forward. Link to comment Share on other sites More sharing options...
Medeek Posted yesterday at 06:06 AM Author Share Posted yesterday at 06:06 AM Version 4.6.1 - 06.06.2026- Added tread covers, carpet and stair runners for all curved stair assemblies.- Enabled a “code” clearance envelope for curved (elliptical and circular) stairs. Link to comment Share on other sites More sharing options...
