GeneDavis Posted July 15, 2025 Share Posted July 15, 2025 I installed it yesterday and I can only run it as an administrator. Where do I go to change this? Link to comment Share on other sites More sharing options...
BenMerritt Posted July 15, 2025 Share Posted July 15, 2025 What happens when you try to run it as non-admin? My best guess is that some data file under your user directory has gotten marked as "owned by admin" by a previous run of Chief as administrator. If so, locating the file and changing its permissions/ownership should sort that out. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 15, 2025 Author Share Posted July 15, 2025 @BenMerrittI cannot open the program at all unless I go the "open as administrator" route. A double-click on the desktop icon results in a little spinning circle, but it goes away, and the program won't open. Same behavior if I right-click and click "open." No open. I've no idea how I can find a data file tagged "owned by administrator." Been a user since 10.08 and never had this issue. Link to comment Share on other sites More sharing options...
JKEdmo Posted July 15, 2025 Share Posted July 15, 2025 It's a Windows thing: Find your Chief program icon. Right click it and got to "Properties." Make sure the box below is unchecked. Mine is from Windows 11. Windows 10 should be very similar. 1 Link to comment Share on other sites More sharing options...
BenMerritt Posted July 16, 2025 Share Posted July 16, 2025 18 hours ago, GeneDavis said: I cannot open the program at all unless I go the "open as administrator" route. A double-click on the desktop icon results in a little spinning circle, but it goes away, and the program won't open. Beautiful. The good old "universal error message." The fact that you've able to run it as an administrator does suggest that it's some kind of permissions issue with some file, whether that's one of the installed program files, one of the multi-user data files, or one of the per-user files. I'd probably do the following: Check the permissions on your "hidden user settings" folder. It's usually at "C:\Users\(your username)\AppData\Local\Chief Architect Premier X17". Right-click on that folder, go to Properties → Security → Advanced, and make sure that your account is listed as the owner near the top of that dialog. Check the "Message Log" file in that folder to see if there are any log messages from the last time you tried to launch the program as a non-admin. If there are, there may be some clues as to which file is causing the trouble. If not, I'd try a clean reinstall of the program to make sure that the issue isn't one of the installed program files (e.g. the ones under "C:\Program Files\Chief Architect"). Link to comment Share on other sites More sharing options...
MoeGia Posted July 28, 2025 Share Posted July 28, 2025 @BenMerrittI have been having some issues with running Chief (slow, crashing). I followed your directions to check on my settings. On the Advanced tab, the Owner is listed as SYSTEM, not me. Should my name be the Owner? Thanks, Link to comment Share on other sites More sharing options...
BenMerritt Posted July 28, 2025 Share Posted July 28, 2025 If you're looking specifically at the "hidden user settings" folder (C:\Users\(your username)\AppData\Local\Chief Architect Premier X17), then yes, I'd expect that to be owned by your own user account rather than SYSTEM. However, it's very unlikely that the permissions on the folder are related to Chief's slow performance. Under certain circumstances, they might theoretically cause crashes, although I haven't verified that. Link to comment Share on other sites More sharing options...
MoeGia Posted August 2, 2025 Share Posted August 2, 2025 @BenMerrittThank you. I'll keep digging. Link to comment Share on other sites More sharing options...
