DefinedDesign Posted June 19, 2025 Share Posted June 19, 2025 I’m using Chief X16 and trying to extend the siding downward to cover some of the foundation slab—but only on specific walls. Right now, when I select a single wall and try to make this change, it applies the siding extension to all the perimeter walls, not just the one I selected. Is there a way to control this so the siding only extends only on the selected wall? Any help would be so appreciated—thank you kindly in advance Link to comment Share on other sites More sharing options...
javatom Posted June 20, 2025 Share Posted June 20, 2025 You can make your foundation a pony will with the top wall type set to have siding. 1 Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted June 20, 2025 Solution Share Posted June 20, 2025 1 hour ago, DefinedDesign said: Right now, when I select a single wall and try to make this change, it applies the siding extension to all the perimeter walls, not just the one I selected. Lisa, My first guess is make a copy of your wall type and then apply the wall siding extension to that new wall type. Use the new wall type only where you want this condition. Jim 1 2 Link to comment Share on other sites More sharing options...
DefinedDesign Posted June 20, 2025 Author Share Posted June 20, 2025 13 hours ago, JKEdmo said: make a copy Jim this was the perfect solution!!! Many thanks! Link to comment Share on other sites More sharing options...
rgardner Posted June 21, 2025 Share Posted June 21, 2025 Using a wall material region will allow you to precisely place the facade or finish you want including in portions of a single wall... 1 Link to comment Share on other sites More sharing options...
