X16 running using RTX 3070 and camera views result in crashing frequently. Driver is 32.0.15.7602
GeneDavis
1 hour ago, GeneDavis said:
If you are on X16 with this card and problem free, tell me your driver ID please.
Similar card, newer driver.  No problems.
Thanks to those of you that looked and commented here.
I contacted tech support and got walked through some system settings that seems to have solved the problem.
You don't simply install Xnew whatever and all works well graphically.  I needed to go to System > Display > Graphics and add X16, which had not been done by me when installing X16.
In the screen cap, attached, you can see X15 as an installed app, and X16 below it.  When I opened this up during the tech call, X16 was not there.  I installed it, and now all seems well.  Or so far, all seems well.
