GeneDavis Posted June 9, 2025 Share Posted June 9, 2025 If you are on X16 with this card and problem free, tell me your driver ID please. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 9, 2025 Share Posted June 9, 2025 1 hour ago, GeneDavis said: If you are on X16 with this card and problem free, tell me your driver ID please. Similar card, newer driver. No problems. Link to comment Share on other sites More sharing options...
ericepv Posted June 9, 2025 Share Posted June 9, 2025 RTX 3060 w/ 32.0.15.7652 driver (05/14/2025) - running fine. Link to comment Share on other sites More sharing options...
GeneDavis Posted June 9, 2025 Author Share Posted June 9, 2025 Thanks to those of you that looked and commented here. I contacted tech support and got walked through some system settings that seems to have solved the problem. You don't simply install Xnew whatever and all works well graphically. I needed to go to System > Display > Graphics and add X16, which had not been done by me when installing X16. In the screen cap, attached, you can see X15 as an installed app, and X16 below it. When I opened this up during the tech call, X16 was not there. I installed it, and now all seems well. Or so far, all seems well. Link to comment Share on other sites More sharing options...
