DVIJD2 Posted June 6, 2025 Share Posted June 6, 2025 Hello. I am relatively new to Chief and I have now met a challenge I cannot seem to video tutorial my way out of... I am trying to build the Range Hood from ceiling to countertop in the picture below. There is nothing "ready made" to use and I also tried to use a box hood and corbels, but it does not look correct. Does anyone have any suggestions? Link to comment Share on other sites More sharing options...
ericepv Posted June 6, 2025 Share Posted June 6, 2025 There are several in 3D Warehouse https://3dwarehouse.sketchup.com/search/models?q=plaster+range+hood or if none of those work for you, build your own from polylines converted to 3D solids. There are also a few bonus catalogs you can download from Chief that might have what you need. Link to comment Share on other sites More sharing options...
DVIJD2 Posted June 6, 2025 Author Share Posted June 6, 2025 Thank you for the link to 3D warehouse. It has a hood I could use but it is coming into CA as an entire room and will not let me select only the hood. Do you know if there is a way to explode the room? Link to comment Share on other sites More sharing options...
DBCooper Posted June 6, 2025 Share Posted June 6, 2025 Look for a different symbol. There is no easy way to isolate just that hood in an imported symbol. You could delete all of the surfaces you don't want and then build a new symbol out of it but that would be painful in the case above. It would be much easier to just create it yourself from scratch (and probably a good learning exercise). You could build that hood just using a poly solid for the ends and a box for the middle part. The one in the original picture would only be slightly more complicated because of the extra fillet on the box. Link to comment Share on other sites More sharing options...
ericepv Posted June 6, 2025 Share Posted June 6, 2025 Try this... Plaster Hood 01.dae Link to comment Share on other sites More sharing options...
Solution MarkMc Posted June 6, 2025 Solution Share Posted June 6, 2025 2 hours ago, DVIJD2 said: I am trying to build the Range Hood As DB suggests build it from solids Mantle hood.zip Link to comment Share on other sites More sharing options...
DVIJD2 Posted June 6, 2025 Author Share Posted June 6, 2025 Thank you all! MarkMc... This progression is most helpful! I have never used solids, but this gives me a good idea of what they can do. Link to comment Share on other sites More sharing options...
