HumbleChief Posted June 2, 2025 Share Posted June 2, 2025 I've got a PDF plan that I am annotating in Layout and there seems to be a default arrow style that's spec'd somewhere I can't locate. In plan the Active Defaults include an 'Arrow' field. See pics below. In layout the Active defaults don't have an 'Arrow' field but there's an arrow that shows up with text anyway. In Layout with every arrow added to text I have to select the arrow and change it's properties and the reason I'm posting this is because there's a LOT of arrows. The pic below shows both Active Default dbx and the arrow that is on by default in Layout. Is there a way to change that arrow property in Layout? THANKS Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted June 2, 2025 Solution Share Posted June 2, 2025 7 minutes ago, HumbleChief said: Is there a way to change that arrow property in Layout? In Layout, go to Edit > Default Settings > Text, Callouts and Markers or get there clicking the Wrench icon: Link to comment Share on other sites More sharing options...
HumbleChief Posted June 2, 2025 Author Share Posted June 2, 2025 THANK YOU!!! 1 Link to comment Share on other sites More sharing options...
DBCooper Posted June 2, 2025 Share Posted June 2, 2025 Just an FYI, it looks like it's in both "active defaults" and "default sets" in X17. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 3, 2025 Author Share Posted June 3, 2025 16 hours ago, DBCooper said: Just an FYI, it looks like it's in both "active defaults" and "default sets" in X17. Interesting, not using 17 that much but will explore. Link to comment Share on other sites More sharing options...
