SHCanada2 Posted May 18 Share Posted May 18 I've seen this before, but do not remember how to get it to show. it shows in the preview but not in the plan Has anyone else seen this, and know how to rectify it ...without drawing a new dimension line 17.05.2025_22.58.16_REC.mp4 thanks Link to comment Share on other sites More sharing options...
Solution MPDesign Posted May 18 Solution Share Posted May 18 Maybe its your display wall width is turned off Link to comment Share on other sites More sharing options...
Doug_N Posted May 18 Share Posted May 18 Try pulling the dimension set outside of the others, Maybe none of them have dimension extensions. I see the actual dimension has been moved. I suspect that dimension set does not have the same default set as others. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 18 Author Share Posted May 18 1 hour ago, Doug_N said: Try pulling the dimension set outside of the others, Maybe none of them have dimension extensions. I see the actual dimension has been moved. I suspect that dimension set does not have the same default set as others. hmmm, didn't seem work, but yes they are different one was inside dimensions pulled outside. I dont remember where the other one came from 6 hours ago, MPDesign said: Maybe its your display wall width is turned off what is that? also on this plan is a missing end line for dimensions: but its there in spirit when I click on it ...found the problem(the dimension showed 3 segments when there should have only been 2) with this one. it is catching the bulkhead or drywall which is 1/2" difference. If i remove the tiny 1/2" segment, it shows. Original problem remains Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 18 Author Share Posted May 18 attached from the OOTB template with wall changed to furred dimesion issue.plan Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 18 Author Share Posted May 18 "display wall widths" in the dimensions DBX makes it work Uncheck Display Wall Widths to suppress those portions of the dimension line that measure between two surfaces of the same wall. Both sides of a wall may still be located, but its width will not display. This option is checked by default for most manually drawn dimensions, but is unchecked for Interior Dimensions merci Link to comment Share on other sites More sharing options...
