WhistlerBuilder Posted May 15 Share Posted May 15 Hello Chiefers, I am having trouble getting property lines from surveys to draw correctly using the Input Line tool. I have been having the issue for too long now where when inputing lines from a pdf to do a preliminary site plan a few of the lines draw backwards or in the opposite direction they are supposed to compared to the source plan. I have been just disconnecting the line and flipping them or manually relocating them to close the polyline, then ensuring I have the correct outline when I get a DWG from the surveyor later in the project. I assume I am doing something wrong, or is this a common experience? I live in Canada so the plans come in Meters with the line orientation coming in this format: 269°55'44". I seem to have this issue no matter what Angle Style I use for the Line Input. Any suggestions would be appreciated. I feel like this is likely something simple that I am just missing. Cheers, Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted May 15 Share Posted May 15 If you are trying to type in a "Quadrant Bearing" measurement, chief will let you type something like n33 45 16w and chief will know what is degrees, minutes and seconds. You don;'t have type any degree, minute or second symbol if you add a space between each value. That is the format degrees space minutes space seconds. I believe that also works for "Azimuth Bearing" where you would omit the letters. Link to comment Share on other sites More sharing options...
robdyck Posted May 15 Share Posted May 15 Whether you are drawing in plan view or in a CAD detail, you need to set up a few things: General Cad Defaults - Displayed line length format should be set to meters and 2 or 3 decimal places. Display Line Angle shoudl be set to Azimuth Bearing. Draw a north arrow. Usualyl this will point up on your screen BUT more importantly it should match the orientation of the survey drawing you are referring to. It's rare that a survey drawing is rotated, but it does happen. To draw a line that matches the survey drawing, turn on the display of the line length and line angle. Draw a line that visually looks similar in angle to a property line. Open the line dialog and enter the angle. Close the dialog. Re-open the line dialog and enter the length. You can accomplisht the same task with a polyline, paying close attention to the start and end of the line. If you haven't already, turn on the start and end indicators. Pick one segment of the polyline and enter the angle. Close the dialog, then re-open and enter the length. Repeat for each line segment. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted May 15 Author Share Posted May 15 I followed the instructions above by Rob, and immediately had the same problem. I drew the first two lines, with the first one drawing in the correct orientation, then the next one drew north when it was supposed to draw south. Exact same problem I always have. Link to comment Share on other sites More sharing options...
JiAngelo Posted May 15 Share Posted May 15 Surveyors generally start at a POB (place of beginning) and call out distance & bearings either clockwise or counter-clockwise until returning to POB and closing the polygon. Some lines like outer subdivision boundaries or ROW curves may conflict in bearing direction call out. Keep in mind n33d45'16"w = s33d45'16"e It's just the start and ends flipped. So for any line going the wrong way, delete it and re-enter with bearings reversed. Think of it as a video game and have the map in your head. After a few times you will start to recognize when the bearings head opposite and correct on the fly. Alternately markup the plot as a guide prior to input. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted May 15 Author Share Posted May 15 There is no e / w / n / s notations on the source material. There also is no POB noted on the source material. Adding a N/S to the input line sent it sideways instead of up/down. Even with the north arrow defined in the plan. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 15 Share Posted May 15 Can you post a copy of the survey? 1 Link to comment Share on other sites More sharing options...
robdyck Posted May 15 Share Posted May 15 2 hours ago, WhistlerBuilder said: I followed the instructions above by Rob, and immediately had the same problem. I drew the first two lines, with the first one drawing in the correct orientation, then the next one drew north when it was supposed to draw south. Exact same problem I always have. Yes, there are times when you need to adjust the angle of input by 90,180 or 270 degrees. I've seen different survey types in different provinces, but one of the reasons for this is that a survey of property lines will often treat each line as an individual segment relative to north and what you often don't know is which is the start or end of the line segment. Determining the correct angles can become especially tricky for lines that are very close to 45, 90, 135 degrees, etc. See this illustration: With a little one-on-one over a virtual meeting, you'd get this sorted out. 1 Link to comment Share on other sites More sharing options...
robdyck Posted May 15 Share Posted May 15 It would actually be faster for someone to provide you with the correct polyline based on your survey than it is to try to type up the methods and instructions. For learning / practicing, a training session would go a long way. If there's anything else I could do to help, feel free to send me a PM. 2 Link to comment Share on other sites More sharing options...
JiAngelo Posted May 16 Share Posted May 16 Sorry Whistler. I missed you stated bearings were in this format: 269°55'44 Add or subtract 180 degrees so that the result is within 0-360. It is the same as flipping a line bearing N60dE to S60dW which is what @robdyck's example above illustrates. 1 Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted May 16 Author Share Posted May 16 @robdyck@JiAngelo Thank you both for the help with this. Turns out I was not inputting it wrong or missing a setting, I just needed to be manually adjusting after the fact like you mentioned. While not the solution I was hoping for, at least I know I was inputting the information correctly. Thank you everyone for trying to help! Have a wonderful weekend. Cheers, 1 Link to comment Share on other sites More sharing options...
onthespothome Posted December 8 Share Posted December 8 If you want to manually draw the property lines to match: 1. You need to first set the North Arrow. Goto CAD>North Pointer. Draw this and align it to your survey north arrow. 2. Make sure you have the CAD default set to Quadrant Bearing. edit>Default Settings>CAD>General CAD Choose the layer you want to use for the plotlines Define the line length format (typically units are ', accuracy is 2 decimal places) Set Display line angle as Quadrant Bearing 3. Draw a line for you first plot line, this should be a line that is either perfectly horizontal or vertical on the survey(ie 0.0 rotation or 90d rotation) then edit the line. Lock the start point(or end point) Set the length to match the survey(132.83') Set the angle to the survey angle(N29d37'00"e) Click ok to finish editing that line. 4. Open that line again and see if the Angle is correct it should be 0.0 or 180.0 for horizontal, or 90.0 or 270.0 for vertical If the angle is off, copy the angle, you will use this to adjust the north arrow. 5. Adjust north arrow. Click on the north arrow and choose replicate/transform select rotate and paste the value from 4 place a -in front of the angle. Click ok. 6. Repeat step 3 and 4. The angle should now be correct. 7. Draw your remaining lot lines using the step from 3 move the endpoint of each line using point to point move so all the vertices are connected. 8. You should have lot lines that are now oriented like the survey paper, with the lotlines displaying the proper length and angles. If the survey is correct and you did things correctly, the lines should have formed a closed polyline. If the lines do not close and there is a gap between the last 2 endpoints, either the survey is off, or you made a mistake entering the line lengths and angles 9. If you want to reorient the lotlines so the chief house is horizontal(typical for chief plans) Measure the angle of the front of the house line in the survey. Select the north arrow, and all lotlines. Rotate by negative the angle. Your north arrow and lotlines should rotate and still show the correct angles and lengths Link to comment Share on other sites More sharing options...
