PitMan71 Posted May 15, 2025 Share Posted May 15, 2025 Hello all A little mystery for all of you. Take a look at the attached plan. On the right side of the dormer the eave fascia is not drawing correctly. If the intersecting roof edge is pulled through or away from the main roof, the fascia is drawn as intended. Any idea what's going on here? Thanks for having a look. 26-250006.plan.zip Link to comment Share on other sites More sharing options...
Mark3D Posted May 16, 2025 Share Posted May 16, 2025 I would report this to chief it seems like a bug to me 1 Link to comment Share on other sites More sharing options...
Garybills Posted May 18, 2025 Share Posted May 18, 2025 @PitMan71I had the same results on a test plan in x16 and x17 bata, it just happens on the right side. It happened in my test plan when one room (entry) has a higher ceiling and the roof builds above the main roof and only with eave marked square cut. I turned in a bug report in x17 bata so you might want to send in one for x16. 1 Link to comment Share on other sites More sharing options...
robdyck Posted May 18, 2025 Share Posted May 18, 2025 On 5/15/2025 at 9:51 AM, PitMan71 said: Any idea what's going on here? I can't find any reason; it looks like you've built everything correctly. I would also suggest reporting this. Until then, increasing the fascia depth to 10.6" will provide a match to 7.25". Just keep an eye out for when this fixes itself and then needs to be changed back to 7.25"...and then back to 10.6"...and so on! 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted May 19, 2025 Author Share Posted May 19, 2025 I will for sure report. Thanks to all of you for taking the time to look it over. Shane 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted May 19, 2025 Author Share Posted May 19, 2025 On 5/17/2025 at 9:11 PM, Garybills said: @PitMan71I had the same results on a test plan in x16 and x17 bata, it just happens on the right side. It happened in my test plan when one room (entry) has a higher ceiling and the roof builds above the main roof and only with eave marked square cut. I turned in a bug report in x17 bata so you might want to send in one for x16. Sounds like a bug. I will report to chief. Shane Link to comment Share on other sites More sharing options...
PitMan71 Posted May 20, 2025 Author Share Posted May 20, 2025 From Chief Support: Hi Shane, I have been working on this and am currently unable to find the cause or a solution better than the one you have already offered. I have reported this to the development team to see if they can isolate the issue and come up with a better resolution. Regards,KristopherChief Architect Technical Consultant 1 Link to comment Share on other sites More sharing options...
robdyck Posted May 20, 2025 Share Posted May 20, 2025 @PitMan71 Thanks for posting the update from support! Helpful and good to know when we're on the same page! 1 Link to comment Share on other sites More sharing options...
