Pass thru window blocking elevation view
ChiefChrissy
I used a pass thru window to do a build out around the deck mounted tub.  Now in elevation it will not show what is visible through the window even though my elevation is back clipped to the exterior wall.  How can I make the exterior wall/ window and tile visible in the elevation thru the pass thru window?
Here is what it looks like now.
 1244227026_Screenshot2025-04-22at11_22_55AM.thumb.png.8e2d840bfdd1345bf948a284013a313d.png
Here is what it is supposed to be showing beyond the pass thru window:
1451991174_Screenshot2025-04-22at11_26_11AM.thumb.png.8b8d6fe89ee5a4975176e3cdd4f79720.png
  • 1 month later...
...or just open up the camera and uncheck Clip to Room.
If you set up the camera as a Wall Elevation, it will automatically clip the sides, bottom, top for you (Clip Plane) and it will Clip to Room which cuts off the view of anything beyond the defined room.  You can take advantage of the automatic Clip Plane behavior and just forgo the one Room clipping behavior though by unchecking the aforementioned setting.
