KevinMyers Posted April 10, 2025 Share Posted April 10, 2025 Is there an easy way to have cabinets that are against each other show a 3/4" face frame on each cabinet that would create a total of 1 1/2" face frame between cabinets instead of 3" between cabinets? But still have 1 1/2" face frame on the outside of cabinets that are on the end of a run? And also keep 1 1/2" face frame on the top and bottom rails. For example on this attached pic, I would like 1 1/2" face frame on the left side of the cabinet next to the wall, but then a total of 1 1/2" face frame between the 2 doors instead of 3 inches. Does it have to be done by adjusting each cabinet individually? Link to comment Share on other sites More sharing options...
joey_martin Posted April 10, 2025 Share Posted April 10, 2025 Link to comment Share on other sites More sharing options...
DBCooper Posted April 10, 2025 Share Posted April 10, 2025 Joey's method works if you want all of the rails and stiles to be 3/4". If you just want either the left or right stile to be 3/4", you need to do that on the cabinet sides page of the cabinet dialog and it only shows up if your cabinet is a face frame cabinet. Link to comment Share on other sites More sharing options...
MarkMc Posted April 10, 2025 Share Posted April 10, 2025 Another method is to set one stile to 0" in the defaults but leave the separation under box construction as 1-1/2". For the last cabinet in a run, click the wrench so it switches to default (1-2"). Better still is to make some style palettes that copy the face configurations you need with the stiles set that way. You can always flip a cabinet to change the side that is 0" (ctrl + F) 1 Link to comment Share on other sites More sharing options...
KevinMyers Posted April 16, 2025 Author Share Posted April 16, 2025 Thanks for the replies! I will be trying out these methods to see what works for us. Link to comment Share on other sites More sharing options...
