JKEdmo Posted Wednesday at 09:10 PM Share Posted Wednesday at 09:10 PM What's the best way to do a swimming pool (simple rectangular / one depth)? First time sticking my toe in the pool. Thanks, Jim Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted Wednesday at 09:18 PM Solution Share Posted Wednesday at 09:18 PM 7 minutes ago, JKEdmo said: What's the best way to do a swimming pool (simple rectangular / one depth)? Try this Knowledge Base article: https://www.chiefarchitect.com/support/article/KB-00773/creating-a-custom-in-ground-swimming-pool.html 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted Wednesday at 09:22 PM Author Share Posted Wednesday at 09:22 PM 3 minutes ago, Chrisb222 said: Try this Knowledge Base article: https://www.chiefarchitect.com/support/article/KB-00773/creating-a-custom-in-ground-swimming-pool.html Thanks! Jim Link to comment Share on other sites More sharing options...
basketballman Posted Wednesday at 10:14 PM Share Posted Wednesday at 10:14 PM 1 hour ago, JKEdmo said: What's the best way to do a swimming pool (simple rectangular / one depth)? First time sticking my toe in the pool. Thanks, Jim " Or they have this one in Chief Library " Link to comment Share on other sites More sharing options...
JKEdmo Posted Wednesday at 10:52 PM Author Share Posted Wednesday at 10:52 PM 37 minutes ago, basketballman said: " Or they have this one in Chief Library " thank you! Link to comment Share on other sites More sharing options...
Renerabbitt Posted Wednesday at 11:07 PM Share Posted Wednesday at 11:07 PM Do it with a room. Set the room ceiling height and floor accordingly so that is sunken, add a cove molding for the base of the pool, add a pool deck molding and feature molding. Use the ceiling surface as your pool water. Save it as a default room type or style palette Link to comment Share on other sites More sharing options...
JKEdmo Posted Wednesday at 11:32 PM Author Share Posted Wednesday at 11:32 PM 24 minutes ago, Renerabbitt said: Do it with a room. Set the room ceiling height and floor accordingly so that is sunken, add a cove molding for the base of the pool, add a pool deck molding and feature molding. Use the ceiling surface as your pool water. Save it as a default room type or style palette Thanks for the tip! Link to comment Share on other sites More sharing options...
