JKEdmo Posted April 9, 2025 Share Posted April 9, 2025 What's the best way to do a swimming pool (simple rectangular / one depth)? First time sticking my toe in the pool. Thanks, Jim Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted April 9, 2025 Solution Share Posted April 9, 2025 7 minutes ago, JKEdmo said: What's the best way to do a swimming pool (simple rectangular / one depth)? Try this Knowledge Base article: https://www.chiefarchitect.com/support/article/KB-00773/creating-a-custom-in-ground-swimming-pool.html 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted April 9, 2025 Author Share Posted April 9, 2025 3 minutes ago, Chrisb222 said: Try this Knowledge Base article: https://www.chiefarchitect.com/support/article/KB-00773/creating-a-custom-in-ground-swimming-pool.html Thanks! Jim Link to comment Share on other sites More sharing options...
basketballman Posted April 9, 2025 Share Posted April 9, 2025 1 hour ago, JKEdmo said: What's the best way to do a swimming pool (simple rectangular / one depth)? First time sticking my toe in the pool. Thanks, Jim " Or they have this one in Chief Library " Link to comment Share on other sites More sharing options...
JKEdmo Posted April 9, 2025 Author Share Posted April 9, 2025 37 minutes ago, basketballman said: " Or they have this one in Chief Library " thank you! Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 9, 2025 Share Posted April 9, 2025 Do it with a room. Set the room ceiling height and floor accordingly so that is sunken, add a cove molding for the base of the pool, add a pool deck molding and feature molding. Use the ceiling surface as your pool water. Save it as a default room type or style palette Link to comment Share on other sites More sharing options...
JKEdmo Posted April 9, 2025 Author Share Posted April 9, 2025 24 minutes ago, Renerabbitt said: Do it with a room. Set the room ceiling height and floor accordingly so that is sunken, add a cove molding for the base of the pool, add a pool deck molding and feature molding. Use the ceiling surface as your pool water. Save it as a default room type or style palette Thanks for the tip! Link to comment Share on other sites More sharing options...
