SHCanada2 Posted April 5, 2025 Share Posted April 5, 2025 Is there a way to get this front gable to extend to the main gable, automatically? The front entry has a different room height. It it was the same room height then it does automatically extend rooftest.plan Link to comment Share on other sites More sharing options...
Mark3D Posted April 5, 2025 Share Posted April 5, 2025 What this video or use automatic roofs with setting correct ceiling heights Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 5, 2025 Author Share Posted April 5, 2025 19 minutes ago, Mark3D said: or use automatic roofs with setting correct ceiling heights I want the ceiling height to be different though and still want it to be automatic. Not possible maybe... Link to comment Share on other sites More sharing options...
Mark3D Posted April 5, 2025 Share Posted April 5, 2025 Open the room dialog and adjust rough ceiling height Link to comment Share on other sites More sharing options...
Mark3D Posted April 5, 2025 Share Posted April 5, 2025 I downloaded you file and something funny is going on I will investigate Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 6, 2025 Author Share Posted April 6, 2025 I think all I did was draw four walls then drew the entry, then changed the ceiling height on the entry. set the gables. Link to comment Share on other sites More sharing options...
Mark3D Posted April 6, 2025 Share Posted April 6, 2025 Sorry i missed that this is the way chief handles those roof situations I don't know why this happens, but it does happen it has been talked about on this forum but I don't know there is way to get auto roofs to handle it. What i do is start with auto roof and then do a manual edit at the end rooftest.plan Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 6, 2025 Author Share Posted April 6, 2025 1 hour ago, Mark3D said: What i do is start with auto roof and then do a manual edit at the end ok thanks, good to know its not available automatically. For this house I am actually using a roof baseline polyline (I saw a video by rene, and thought, wow that is a quick way to fix up the roof after the auto build is done), so I was really hoping as well, that somehow modifying the roof baseline polyline somehow would make the roof connect to the main roof. But no luck ...so far Link to comment Share on other sites More sharing options...
Solution glennw Posted April 6, 2025 Solution Share Posted April 6, 2025 I have always done that by creating a room with invisible walls in the main room. The vertical wall that defines the invisible room only needs to encroach on the large room as far as it meets the valleys on either side. You shouldn't need to use a Roof Baseline Polyline. rooftestGLENN.plan Link to comment Share on other sites More sharing options...
Mark3D Posted April 6, 2025 Share Posted April 6, 2025 If you mix glens smart idea with Make roof base polyline it works with auto roof and you can loose the invisible walls Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 6, 2025 Author Share Posted April 6, 2025 12 hours ago, Mark3D said: If you mix glens smart idea with Make roof base polyline it works with auto roof and you can loose the invisible walls I think I saw that in another post, put in the invisible walls, generate the roof, remove the walls. Thanks @glennwthis:: invisible room only needs to encroach on the large room as far as it meets the valleys on either side. are the tidbits on information that even if I was to do it once, I usually forget the next time. ...now when I search the forum I will sometimes search by my name to try and remember the ones I know I asked about but do not remember the answer! Link to comment Share on other sites More sharing options...
