DennisL Posted April 3, 2025 Share Posted April 3, 2025 I am designing a two story garage with three overhead doors. above the doors the walls are stacked up so the face of the first floor and second floor line up flush. I want to put a two foot deep with an 8" pitch roof with a level soffit under it. I would prefer to hip the left and right end of the design to look like a hip roof. I cannot seem to get this right at all. Any help on how to add this would be much appreciated. Thanks in advance! Dennis Letendre Letendre Custom Woodworks, Inc. Link to comment Share on other sites More sharing options...
Doug_N Posted April 3, 2025 Share Posted April 3, 2025 9 minutes ago, DennisL said: I am designing a two story garage with three overhead doors. above the doors the walls are stacked up so the face of the first floor and second floor line up flush. I want to put a two foot deep with an 8" pitch roof with a level soffit under it. I would prefer to hip the left and right end of the design to look like a hip roof. I cannot seem to get this right at all. Any help on how to add this would be much appreciated. Thanks in advance! Dennis Letendre Letendre Custom Woodworks, Inc. Hi Dennis, If you have started this project, then posting the plan file may help someone to answer your question. Also a photo of an example might be clearer than your posed question. Something like this? Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted April 3, 2025 Solution Share Posted April 3, 2025 Are you talking about something like this lower awning roof or eyebrow overhang thing? 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted April 3, 2025 Share Posted April 3, 2025 You can accomplish this using roof planes. Then you will need to check Boxed Eave:" and set to the depth of your overhang, in your case 24". Create any brackets you want with 3d solids. I learned how to do manually roofs with this video. It will be helpful when building a roof where there is no room definition. Good luck. Link to comment Share on other sites More sharing options...
PitMan71 Posted April 3, 2025 Share Posted April 3, 2025 This is a great video also. Link to comment Share on other sites More sharing options...
MoeGia Posted April 4, 2025 Share Posted April 4, 2025 There are brackets/corbels in the library. Link to comment Share on other sites More sharing options...
Doug_N Posted April 4, 2025 Share Posted April 4, 2025 Link to comment Share on other sites More sharing options...
DennisL Posted April 4, 2025 Author Share Posted April 4, 2025 Garage Roof Over Doors.plan Link to comment Share on other sites More sharing options...
DennisL Posted April 4, 2025 Author Share Posted April 4, 2025 On 4/3/2025 at 11:33 AM, Alaskan_Son said: Are you talking about something like this lower awning roof or eyebrow overhang thing? This is exactly what I am talking about! Great Job! Can you advise me on how to do this? Thank you so much! Dennis Link to comment Share on other sites More sharing options...
Doug_N Posted April 4, 2025 Share Posted April 4, 2025 1 hour ago, DennisL said: This is exactly what I am talking about! Great Job! Can you advise me on how to do this? Thank you so much!` Dennis Dennis, Please watch the video. Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 5, 2025 Share Posted April 5, 2025 2 hours ago, DennisL said: This is exactly what I am talking about! Great Job! Can you advise me on how to do this? Thank you so much! Dennis Its nothing more than a simple manual roof that I dragged out across the front of the building. You could probably force it to auto build with some invisible walls, but manual is super easy. Just drag out the 3 little roof planes and join them up... https://rumble.com/v6ro2x7-quick-awning-roof.html 1 Link to comment Share on other sites More sharing options...
DennisL Posted April 5, 2025 Author Share Posted April 5, 2025 18 hours ago, Alaskan_Son said: Its nothing more than a simple manual roof that I dragged out across the front of the building. You could probably force it to auto build with some invisible walls, but manual is super easy. Just drag out the 3 little roof planes and join them up... https://rumble.com/v6ro2x7-quick-awning-roof.html Thank you so much! I watched the video and it looks pretty easy! Thanks again! Dennis Link to comment Share on other sites More sharing options...
