GeneDavis Posted 17 hours ago Share Posted 17 hours ago For a house framed with exterior walls in 2x6, interior walls in 2x4, and 9/0 nominal ceilings everywhere, I set the buy list to have two lengths only of each size. Thus for 2x6 size, the two lengths are 8'-8 5/8" and 16'. My problem is that the wall plates (and maybe opening header parts also), many being less than 8'-8 5/8", seem to be chopped from the shorter parts, and not the 16s. I have checked in the setup for structural member reporting that wall plates are to come from longest size, but I don't know how this works in the code to produce buy list part counts. In the image attached, a screencap from my material list, you can see plenty of the 9/0 precut buy list parts counted to do wall plates and headers. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 16 hours ago Share Posted 16 hours ago Go into Structural Member Reporting and Increase Priority for the longer material lengths. Link to comment Share on other sites More sharing options...
GeneDavis Posted 14 hours ago Author Share Posted 14 hours ago OK @Alaskan_Son, things are not going the way I want. In my job with all walls nominally 9/0 tall, studs all the precuts at 8'-8 5/8", there are a lot of door and window openings with trimmer in 8'-1" lengths, and the material list buy list is wanting to cut every one of these from a 16' piece. Per your observation and comment, I've sequenced the member reporting with two lengths only, 15' first, then 8'-8 5/8". Pieces 8'-1" go first to the 16, get cut, leave 7'-11 minus the kerf, and I get stuck with a whole bunch of off falls at this length. What can be done to ensure the trimmers instead get cut from the 8'-8 5/8" lengths? Shouldn't a part first go for the nearest buy length that first exceeds the cut length? Link to comment Share on other sites More sharing options...
