IRDesign Posted February 4, 2025 Share Posted February 4, 2025 Help! I've spent far too much time on this.... I am trying to put this slab with a hole in it up on it's side so that it is vertical and I can't figure it out. Any advise? Link to comment Share on other sites More sharing options...
TeaTime Posted February 4, 2025 Share Posted February 4, 2025 Try creating it as a 3D Solid instead of a slab. The Slab tool is for like, a building slab. Just a flat slab with a specified thickness. 3D Solids can be anything. Also you can just create that shape in an Elevation view using 3D Solids so you won't have to rotate it. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 4, 2025 Share Posted February 4, 2025 Select the Slab, click the Convert to 3D Solid tool, and then simply select by one of the sides and Rotate. Link to comment Share on other sites More sharing options...
TeaTime Posted February 4, 2025 Share Posted February 4, 2025 21 minutes ago, Alaskan_Son said: Select the Slab, click the Convert to 3D Solid tool, and then simply select by one of the sides and Rotate. Oh yeah, that too. But in the future, don't use Slabs to draw that type of thing Link to comment Share on other sites More sharing options...
DBCooper Posted February 5, 2025 Share Posted February 5, 2025 Also, depending on what you want to do with it after, you could convert it directly into a symbol. Link to comment Share on other sites More sharing options...
IRDesign Posted February 11, 2025 Author Share Posted February 11, 2025 Thank you ALL for your help. So simple, that I couldn't figure it out! Link to comment Share on other sites More sharing options...
