DenisonDrywall Posted February 3, 2025 Share Posted February 3, 2025 The drywall on my walls disappeared. these are existing walls on their own layer. the new walls show up fine. They were showing up fine last week but when I opened the drawing today, its like this - no drywall showing. I didn't change any layers or turn any off. how do I get my drywall back? thanks, plan.zip Link to comment Share on other sites More sharing options...
PitMan71 Posted February 3, 2025 Share Posted February 3, 2025 Looks like the plywood is the where the drywall was. Did you check the wall type definition? Your attached plan downloaded but didn't open for me. Shane Link to comment Share on other sites More sharing options...
PitMan71 Posted February 3, 2025 Share Posted February 3, 2025 It looks like maybe the OSB material got applied to your drywall. Link to comment Share on other sites More sharing options...
DenisonDrywall Posted February 3, 2025 Author Share Posted February 3, 2025 I had thought that too, but if you look closely, the window224-0496 Drautz, Kim - opt3.zip frames protrude out into the wall. i turned on the framing and it confirmed that the drywall just disapeared. i renamed the folder so maybe that's why it wouldn't open. Link to comment Share on other sites More sharing options...
robdyck Posted February 3, 2025 Share Posted February 3, 2025 12 minutes ago, DenisonDrywall said: i renamed the folder so maybe that's why it wouldn't open. The plan file must be closed before zipping and posting the link. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted February 3, 2025 Share Posted February 3, 2025 Yep. I see what you are talking about. I downloaded again and its showing the contents of the zip file is Zero bytes. i dunno whats happening. Maybe someone else is having better luck. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 3, 2025 Share Posted February 3, 2025 Jennifer, Close the plan in Chief before zipping it. Then upload here. Link to comment Share on other sites More sharing options...
DenisonDrywall Posted February 4, 2025 Author Share Posted February 4, 2025 224-0496 Drautz, Kim - opt3 (3).zip Trying this again. :-) Link to comment Share on other sites More sharing options...
robdyck Posted February 4, 2025 Share Posted February 4, 2025 It's because your drywall layer is marked as framing. Uncheck Framing and Auto detail as insulation (Auto detail as insulation doesn't affect the 3d build) and it will build correctly. 1 Link to comment Share on other sites More sharing options...
DenisonDrywall Posted February 4, 2025 Author Share Posted February 4, 2025 Thank you! That was it. Not sure how that setting was changed.... Link to comment Share on other sites More sharing options...
Darcen Posted February 5, 2025 Share Posted February 5, 2025 That was it! I've fought that for days! You guys are good! Thanks! Link to comment Share on other sites More sharing options...
