Dimension Setting
DesignBuild
In older versions of CA under Appearance you could set the minimum display size for dimensions. The setting now allows only the setting of the minimum size for temp dims. Is it somewhere else? Hard to believe a person can no longer set this. When I zoom out everything is now too small for viewing.
Huh, I never noticed that. I always migrate my preference settings so I didn't realize the change, and it wasn't mentioned in the new features document.
I like this change, I always had mine set at 1 pixel but now I can increase that, and be able to see temp dims when zoomed out without cluttering the screen with all the huge printed dimensions.
I know you don't like it, perhaps post a suggestion to add a toggle to select which mode you prefer, or a setting for both temp and printed dims?
https://chieftalk.chiefarchitect.com/forum/8-suggestions/
  • 1 month later...
Did you get this figured out?
All of the sudden I am having this problem. They changed the program in X16.
  • 4 months later...
This just happened again in X16...
