DesignBuild Posted February 2, 2025 Share Posted February 2, 2025 In older versions of CA under Appearance you could set the minimum display size for dimensions. The setting now allows only the setting of the minimum size for temp dims. Is it somewhere else? Hard to believe a person can no longer set this. When I zoom out everything is now too small for viewing. Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 3, 2025 Share Posted February 3, 2025 On 2/2/2025 at 12:10 AM, DesignBuild said: In older versions of CA under Appearance you could set the minimum display size for dimensions. The setting now allows only the setting of the minimum size for temp dims. Is it somewhere else? Hard to believe a person can no longer set this. When I zoom out everything is now too small for viewing. Huh, I never noticed that. I always migrate my preference settings so I didn't realize the change, and it wasn't mentioned in the new features document. I like this change, I always had mine set at 1 pixel but now I can increase that, and be able to see temp dims when zoomed out without cluttering the screen with all the huge printed dimensions. I know you don't like it, perhaps post a suggestion to add a toggle to select which mode you prefer, or a setting for both temp and printed dims? https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Link to comment Share on other sites More sharing options...
CharlesVolz Posted March 7, 2025 Share Posted March 7, 2025 On 2/1/2025 at 11:10 PM, DesignBuild said: In older versions of CA under Appearance you could set the minimum display size for dimensions. The setting now allows only the setting of the minimum size for temp dims. Is it somewhere else? Hard to believe a person can no longer set this. When I zoom out everything is now too small for viewing. Did you get this figured out? All of the sudden I am having this problem. They changed the program in X16. Link to comment Share on other sites More sharing options...
CharlesVolz Posted July 25, 2025 Share Posted July 25, 2025 On 3/7/2025 at 5:56 PM, CharlesVolz said: Did you get this figured out? All of the sudden I am having this problem. They changed the program in X16. This just happened again in X16... Link to comment Share on other sites More sharing options...
MPDesign Posted July 25, 2025 Share Posted July 25, 2025 I believe the dimension text size is set by layer now. That is why the option is only for temp dimensions now. Link to comment Share on other sites More sharing options...
