decorators3 Posted January 29 Share Posted January 29 Good Morning I am attaching rough renderings I've done for my client ( only the front ) the rest of the house roof is a mess,, I cant seem to get the roof design done properly based on the plans PDF..I was going to start over from scratch but the client wanted to see something so I sent only the front so we can make changes - now I have a little time to work with the roof but I'm so frustrated - I've reached out to the drafting firm that did the design for a roof schematic ( find the roof lines on the floor plan confusing) but have not heard back from them I'm looking for someone to design the roof for me . I will pay for your services but I'm Canadian and with the US exchange rate I'd like to work with someone from Canada if possible ( No disrespect intended and please don't take offense ) Levina B_Mathews -Slab on grade (1).pdf Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29 Share Posted January 29 So you've a full set of construction docs a drafting firm did for the client? Can you scan and post the roof plan and all four elevations, as done by them? Link to comment Share on other sites More sharing options...
decorators3 Posted January 29 Author Share Posted January 29 2 minutes ago, GeneDavis said: So you've a full set of construction docs a drafting firm did for the client? Can you scan and post the roof plan and all four elevations, as done by them? I only have the PDF that I attached Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29 Share Posted January 29 OK I see the drawings. Does your X16 plan have a floor plan that matches precisely what is on those prints? Every roof-bearing wall in same config? All dimensions check out? If so, close the file, zip it, and post it here. Link to comment Share on other sites More sharing options...
decorators3 Posted January 29 Author Share Posted January 29 9 minutes ago, GeneDavis said: OK I see the drawings. Does your X16 plan have a floor plan that matches precisely what is on those prints? Every roof-bearing wall in same config? All dimensions check out? If so, close the file, zip it, and post it here. its a mess mathews file for ca.zip Link to comment Share on other sites More sharing options...
decorators3 Posted January 29 Author Share Posted January 29 8 hours ago, decorators3 said: its a mess mathews file for ca.zip 4.79 MB · 14 downloads Hi Steve I don't expect you to to fix it on your time. This is an important client so trying to get it right as he wants to see the rear as well. I'm ok with the exchange rate if you take it on because I know you're really good at what you do. You helped me out a while back with rendering tips etc ,...BUT this is a complete mess if not worth your time I'm ok with that too. I can restart and try with roof planes as opposed to auto roofs which probably was my error in the first place Levina Link to comment Share on other sites More sharing options...
decorators3 Posted Thursday at 11:54 AM Author Share Posted Thursday at 11:54 AM 15 hours ago, decorators3 said: Hi Steve I don't expect you to to fix it on your time. This is an important client so trying to get it right as he wants to see the rear as well. I'm ok with the exchange rate if you take it on because I know you're really good at what you do. You helped me out a while back with rendering tips etc ,...BUT this is a complete mess if not worth your time I'm ok with that too. I can restart and try with roof planes as opposed to auto roofs which probably was my error in the first place Levina thanks Steve all adjusted,, Link to comment Share on other sites More sharing options...
robdyck Posted Thursday at 02:40 PM Share Posted Thursday at 02:40 PM On 1/29/2025 at 4:47 AM, decorators3 said: I'm looking for someone to design the roof for me . I will pay for your services but I'm Canadian and with the US exchange rate I'd like to work with someone from Canada if possible ( No disrespect intended and please don't take offense ) Levina If you still need help, feel free to email me or send me a PM. Link to comment Share on other sites More sharing options...
decorators3 Posted Thursday at 11:43 PM Author Share Posted Thursday at 11:43 PM 8 hours ago, robdyck said: If you still need help, feel free to email me or send me a PM. I do have it fixed somewhat but was told but it is still not correct. , and a bit messy.. however for what I need to send to the client I think its ok... I am only creating an exterior rendering of the 4 sides for materials etc.. plus deck so hopefully its ok Cheers Levina Link to comment Share on other sites More sharing options...
