decorators3
Good Morning
I am attaching  rough  renderings  I've done for my client ( only the front ) the rest of the house roof is a mess,, I cant seem to get the roof design  done properly based on the plans PDF..I was going to start over from scratch but the client wanted to see something so I sent only the front so we can make changes - now I have a little time to work with the roof but I'm  so frustrated -  I've reached out to the drafting firm that did the design for a roof schematic  ( find the roof lines on the floor plan confusing) but have not heard back from them
I'm  looking for someone  to design the roof for me .  I will pay for your services but I'm Canadian and with the US exchange rate I'd like to work with someone from Canada if possible ( No disrespect intended and please don't take offense  )
Levina
B_Mathews -Slab on grade (1).pdf
2 minutes ago, GeneDavis said:
So you've a full set of construction docs a drafting firm did for the client?  Can you scan and post the roof plan and all four elevations, as done by them?
I only have the PDF that I attached
OK I see the drawings.
Does your X16 plan have a floor plan that matches precisely what is on those prints?  Every roof-bearing wall in same config?  All dimensions check out?
If so, close the file, zip it, and post it here.
8 hours ago, decorators3 said:
Hi Steve
  I don't expect you to  to fix it on your time.  This is an important client so trying to get it right as he wants to see the rear as well.  I'm  ok with the exchange rate if you take it on because I know you're really good at what you do. You helped me out a while back with  rendering tips etc ,...BUT this is  a complete mess if not worth your time I'm ok with that too.
I can restart and try with roof planes as opposed to auto roofs which probably was my error in the  first place
Levina
15 hours ago, decorators3 said:
Hi Steve
Levina
thanks Steve all adjusted,,
Levina
If you still need help, feel free to email me or send me a PM.
I do have it fixed somewhat but was told but it is still not correct. , and a bit messy.. however for what I need to send to the client  I think its ok...  I am  only creating an exterior rendering of the 4 sides for materials etc.. plus deck so hopefully its ok
Cheers
Levina
  • 3 weeks later...
Cheers
Levina
Hi
I am having trouble with another roof and I need help >> I will pay for your service- this is a great forum and I don't want to seem like I'm passing my roof work to someone else- but when  I've tried several times to get it right its frustrating so I need to reach out.   if you can help me I can be reached through my email  levina429@gmail.com
I'm Living in St. Johns, NL
Hope to hear from you
Cheers
Levina
Levoina
