decorators3 Posted January 29, 2025 Share Posted January 29, 2025 Good Morning I am attaching rough renderings I've done for my client ( only the front ) the rest of the house roof is a mess,, I cant seem to get the roof design done properly based on the plans PDF..I was going to start over from scratch but the client wanted to see something so I sent only the front so we can make changes - now I have a little time to work with the roof but I'm so frustrated - I've reached out to the drafting firm that did the design for a roof schematic ( find the roof lines on the floor plan confusing) but have not heard back from them I'm looking for someone to design the roof for me . I will pay for your services but I'm Canadian and with the US exchange rate I'd like to work with someone from Canada if possible ( No disrespect intended and please don't take offense ) Levina B_Mathews -Slab on grade (1).pdf Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2025 Share Posted January 29, 2025 So you've a full set of construction docs a drafting firm did for the client? Can you scan and post the roof plan and all four elevations, as done by them? Link to comment Share on other sites More sharing options...
decorators3 Posted January 29, 2025 Author Share Posted January 29, 2025 2 minutes ago, GeneDavis said: So you've a full set of construction docs a drafting firm did for the client? Can you scan and post the roof plan and all four elevations, as done by them? I only have the PDF that I attached Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2025 Share Posted January 29, 2025 OK I see the drawings. Does your X16 plan have a floor plan that matches precisely what is on those prints? Every roof-bearing wall in same config? All dimensions check out? If so, close the file, zip it, and post it here. Link to comment Share on other sites More sharing options...
decorators3 Posted January 29, 2025 Author Share Posted January 29, 2025 9 minutes ago, GeneDavis said: OK I see the drawings. Does your X16 plan have a floor plan that matches precisely what is on those prints? Every roof-bearing wall in same config? All dimensions check out? If so, close the file, zip it, and post it here. its a mess mathews file for ca.zip Link to comment Share on other sites More sharing options...
decorators3 Posted January 29, 2025 Author Share Posted January 29, 2025 8 hours ago, decorators3 said: its a mess mathews file for ca.zip 4.79 MB · 14 downloads Hi Steve I don't expect you to to fix it on your time. This is an important client so trying to get it right as he wants to see the rear as well. I'm ok with the exchange rate if you take it on because I know you're really good at what you do. You helped me out a while back with rendering tips etc ,...BUT this is a complete mess if not worth your time I'm ok with that too. I can restart and try with roof planes as opposed to auto roofs which probably was my error in the first place Levina Link to comment Share on other sites More sharing options...
decorators3 Posted January 30, 2025 Author Share Posted January 30, 2025 15 hours ago, decorators3 said: Hi Steve I don't expect you to to fix it on your time. This is an important client so trying to get it right as he wants to see the rear as well. I'm ok with the exchange rate if you take it on because I know you're really good at what you do. You helped me out a while back with rendering tips etc ,...BUT this is a complete mess if not worth your time I'm ok with that too. I can restart and try with roof planes as opposed to auto roofs which probably was my error in the first place Levina thanks Steve all adjusted,, Link to comment Share on other sites More sharing options...
robdyck Posted January 30, 2025 Share Posted January 30, 2025 On 1/29/2025 at 4:47 AM, decorators3 said: I'm looking for someone to design the roof for me . I will pay for your services but I'm Canadian and with the US exchange rate I'd like to work with someone from Canada if possible ( No disrespect intended and please don't take offense ) Levina If you still need help, feel free to email me or send me a PM. Link to comment Share on other sites More sharing options...
decorators3 Posted January 30, 2025 Author Share Posted January 30, 2025 8 hours ago, robdyck said: If you still need help, feel free to email me or send me a PM. I do have it fixed somewhat but was told but it is still not correct. , and a bit messy.. however for what I need to send to the client I think its ok... I am only creating an exterior rendering of the 4 sides for materials etc.. plus deck so hopefully its ok Cheers Levina Link to comment Share on other sites More sharing options...
decorators3 Posted February 18, 2025 Author Share Posted February 18, 2025 On 1/30/2025 at 8:13 PM, decorators3 said: I do have it fixed somewhat but was told but it is still not correct. , and a bit messy.. however for what I need to send to the client I think its ok... I am only creating an exterior rendering of the 4 sides for materials etc.. plus deck so hopefully its ok Cheers Levina On 1/30/2025 at 11:10 AM, robdyck said: If you still need help, feel free to email me or send me a PM. Hi I am having trouble with another roof and I need help >> I will pay for your service- this is a great forum and I don't want to seem like I'm passing my roof work to someone else- but when I've tried several times to get it right its frustrating so I need to reach out. if you can help me I can be reached through my email levina429@gmail.com I'm Living in St. Johns, NL Hope to hear from you Cheers Levina Levoina Link to comment Share on other sites More sharing options...
robdyck Posted February 18, 2025 Share Posted February 18, 2025 @decorators3I'll email you shortly. Link to comment Share on other sites More sharing options...
