CoastlineFl Posted January 25, 2025 Share Posted January 25, 2025 I found this same question in another thread but it didn't really get answered.... I setup a layer called "Doors Ext" so I can see only my exterior doors in certain views. ie Roof plan to verify girders do not land on top of an opening. I open the defaults and go to doors, select exterior door and set it to my new layer. This works but apparently that is not the ultimate default as if I am in a window and check the default box it goes back to "Door" Where is the top level layer default for doors? Bob Deal Coastline Construction, LLC Melbourne Beach, FL X15 and many prior on a MacBook Pro M1 Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2025 Share Posted January 25, 2025 1 hour ago, CoastlineFl said: ie Roof plan to verify girders do not land on top of an opening. For this purpose, you could use a different strategy. In your roof plan, turn on the layer for Opening Header Lines and turn off the layer for Doors. Adjust the layer color and line style to suit your needs. 20250125-1604-40.1543108.mp4 Link to comment Share on other sites More sharing options...
CoastlineFl Posted January 25, 2025 Author Share Posted January 25, 2025 Thanks for the tip. It accomplishes what I needed. Link to comment Share on other sites More sharing options...
DBCooper Posted January 26, 2025 Share Posted January 26, 2025 Just an FYI... If you open up a door in your plan and check "default" next to the layer, then the program will use the system default layer which will always be "doors" and not what you set it to in your door defaults. Changing your default doors to use some other layer should work for any new doors you place but it won't change any already in the plan. If you already have doors in your plan, you will need to set them to the layer you want instead of just checking the "default" box. Link to comment Share on other sites More sharing options...
CoastlineFl Posted January 29, 2025 Author Share Posted January 29, 2025 When you set the layer in the default settings for "Exterior Door" it unchecks the "Default" checkbox. After I save it and go place a door it has the proper layer ("Doors Ext") but it is not the default. So I am wondering is the top level "default" hard coded to "Doors" as DBCooper seems to suggest? Or is there a way to get the check box to apply different layers according to the setup default? Link to comment Share on other sites More sharing options...
MoeGia Posted January 29, 2025 Share Posted January 29, 2025 Defaults, Doors (the little wrench) will allow you to set up door defaults for exterior, interior, sliding, etc. You can only set one type for each category. I keep a few standard type doors in my template plan (or you can add them to your library). It makes it easy to bring in a door with everything preset. Link to comment Share on other sites More sharing options...
