Why doesn't Chief allow for a complete material change when selecting "All"???
John_B
Go to solution Solved by SNestor,
The Custmer wants to change roof and fascia colors and short of touching each and every section of roof and fascia why can't I just select  ALL?  I can select two or three at a time but not more than about 3...this seems ridicluous!
  • John_B changed the title to Why doesn't Chief allow for a complete material change when selecting "All"???
12 hours ago, Alaskan_Son said:
If you don't get the option to change materials, its usually because at least one roof plane has at least one components that the rest do not have.
I'm thinking that this could be but it seems that similar sections still don't select...the plan is in the abov link.
21 minutes ago, DBCooper said:
Also, I don't think Steve's post really qualifies as the solution but I am guessing that Michael is on the right track.
No solution offered...I just did a quick plan and in my template and I am able to change materials...and I have materials. I think Michael has most likely identified the problem.
Yes...pdf doesn't help. Post a plan file...maybe a simple test file?
