KevinMyers Posted January 9 Share Posted January 9 Hello, Has anyone figured out a good way to show panel ready refrigerator/dishwashers/etc.? I have just been placing a door panel in front of the appliance in the correct position, but wondering if I am missing something and there is a better way. 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted January 9 Share Posted January 9 This is a way. Adding special oversized handles to the cabinet seals the deal. I actually don't use an appliance in those situations but just a cabinet. The appliance would be noted in plan view with 'D.W.', etc. Link to comment Share on other sites More sharing options...
MarkMc Posted January 9 Share Posted January 9 As Alan said use cabinets. I keep them in the library already set up with label. Some like fridges I make as arch blocks. Can be as per the attached which is the 1cabinet for surround and another for the panels. For panel sizes here I have noted to see attached. You can float all the panels if you want instead so sizes go into schedule. If you really want to be a weaner can hack the door off of an actual fridge symbol, convert to a new symbol. As a fixture interior you can turn that into a shelf. DW can be a block with a separate cabinet for the body and a door. That way you can get the panel listed in schedule along with size. I've also have standard dishwashers from cabinets that I keep that in the library. Hack the door from a dishwasher symbol using delete surface tool (check forum for instructions by alaskan_son if those are still around) No need to block that just convert the DW door into a cabinet door symbol, set cabinet to not appear in schedule. Gets the countertop without the dumb insert into a cabinet method. Link to comment Share on other sites More sharing options...
KevinMyers Posted January 9 Author Share Posted January 9 40 minutes ago, MarkMc said: As Alan said use cabinets. I keep them in the library already set up with label. Some like fridges I make as arch blocks. Can be as per the attached which is the 1cabinet for surround and another for the panels. For panel sizes here I have noted to see attached. You can float all the panels if you want instead so sizes go into schedule. If you really want to be a weaner can hack the door off of an actual fridge symbol, convert to a new symbol. As a fixture interior you can turn that into a shelf. DW can be a block with a separate cabinet for the body and a door. That way you can get the panel listed in schedule along with size. I've also have standard dishwashers from cabinets that I keep that in the library. Hack the door from a dishwasher symbol using delete surface tool (check forum for instructions by alaskan_son if those are still around) No need to block that just convert the DW door into a cabinet door symbol, set cabinet to not appear in schedule. Gets the countertop without the dumb insert into a cabinet method. Thanks! I may try this idea of using a cabinet instead. I appreciate the response, we are still relatively new users of the program. Link to comment Share on other sites More sharing options...
KevinMyers Posted January 9 Author Share Posted January 9 2 hours ago, Gawdzira said: This is a way. Adding special oversized handles to the cabinet seals the deal. I actually don't use an appliance in those situations but just a cabinet. The appliance would be noted in plan view with 'D.W.', etc. Thanks! I think I will try just using a cabinet and not using the appliance, just notating it. I appreciate the response! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 9 Share Posted January 9 There's no reason you can't model refrigerators and dishwashers using cabinets and then convert them to a fixture symbols and add to you user library. There may also be some such items in the Sketchup 3D Warehouse. Link to comment Share on other sites More sharing options...
