KevinMyers Posted January 9, 2025 Share Posted January 9, 2025 Hello, Has anyone figured out a good way to show panel ready refrigerator/dishwashers/etc.? I have just been placing a door panel in front of the appliance in the correct position, but wondering if I am missing something and there is a better way. 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted January 9, 2025 Share Posted January 9, 2025 This is a way. Adding special oversized handles to the cabinet seals the deal. I actually don't use an appliance in those situations but just a cabinet. The appliance would be noted in plan view with 'D.W.', etc. Link to comment Share on other sites More sharing options...
MarkMc Posted January 9, 2025 Share Posted January 9, 2025 As Alan said use cabinets. I keep them in the library already set up with label. Some like fridges I make as arch blocks. Can be as per the attached which is the 1cabinet for surround and another for the panels. For panel sizes here I have noted to see attached. You can float all the panels if you want instead so sizes go into schedule. If you really want to be a weaner can hack the door off of an actual fridge symbol, convert to a new symbol. As a fixture interior you can turn that into a shelf. DW can be a block with a separate cabinet for the body and a door. That way you can get the panel listed in schedule along with size. I've also have standard dishwashers from cabinets that I keep that in the library. Hack the door from a dishwasher symbol using delete surface tool (check forum for instructions by alaskan_son if those are still around) No need to block that just convert the DW door into a cabinet door symbol, set cabinet to not appear in schedule. Gets the countertop without the dumb insert into a cabinet method. Link to comment Share on other sites More sharing options...
KevinMyers Posted January 9, 2025 Author Share Posted January 9, 2025 40 minutes ago, MarkMc said: As Alan said use cabinets. I keep them in the library already set up with label. Some like fridges I make as arch blocks. Can be as per the attached which is the 1cabinet for surround and another for the panels. For panel sizes here I have noted to see attached. You can float all the panels if you want instead so sizes go into schedule. If you really want to be a weaner can hack the door off of an actual fridge symbol, convert to a new symbol. As a fixture interior you can turn that into a shelf. DW can be a block with a separate cabinet for the body and a door. That way you can get the panel listed in schedule along with size. I've also have standard dishwashers from cabinets that I keep that in the library. Hack the door from a dishwasher symbol using delete surface tool (check forum for instructions by alaskan_son if those are still around) No need to block that just convert the DW door into a cabinet door symbol, set cabinet to not appear in schedule. Gets the countertop without the dumb insert into a cabinet method. Thanks! I may try this idea of using a cabinet instead. I appreciate the response, we are still relatively new users of the program. Link to comment Share on other sites More sharing options...
KevinMyers Posted January 9, 2025 Author Share Posted January 9, 2025 2 hours ago, Gawdzira said: This is a way. Adding special oversized handles to the cabinet seals the deal. I actually don't use an appliance in those situations but just a cabinet. The appliance would be noted in plan view with 'D.W.', etc. Thanks! I think I will try just using a cabinet and not using the appliance, just notating it. I appreciate the response! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 9, 2025 Share Posted January 9, 2025 There's no reason you can't model refrigerators and dishwashers using cabinets and then convert them to a fixture symbols and add to you user library. There may also be some such items in the Sketchup 3D Warehouse. Link to comment Share on other sites More sharing options...
