Help me rotate this stubborn base cabinet
Newbie_Mary
I can't understand the audio.
Describe what you want to accomplish and include some reference to work with; angles, points, arc ...
Assuming the cabinets are to meet at a rear corner and not overlap, then you need the arc for the back NOT the front. Also assuming that all cabinets are to be the same depth?
Angle snaps off, nothing else. The idea is to break your arc into a series of chords whose length equals the width of the cabinets you want to place. As you go you will make the cabinet parallel to the chord, then move the corner of the cabinet to the start of the chord
Set the first cabinet - start with a point of reference- where one corner of one cabinet starts on the arc. I started on the left.
Using that point as center draw a circle about center, radius equals the width of the first cabinet, say 27"
draw a line snapping to that center and then to the intersection of the circle and the arc
select the cabinet and make parallel to that line, then point to point move the left rear corner of that cabinet to the start of the line
NEXT
starting at the right corner of the first cabinet-Draw a circle about center; radius equals width of the next cabinet,
draw line, select cabinet, make parallel, point to point move.
image.thumb.png.5e2b62120c718fd7d99ab91f6f1bcd03.pngimage.thumb.png.1f6b374b0b9f9b8209ce7e66ce02be9b.png
On 12/25/2024 at 7:16 AM, MarkMc said:
Try turning Angle Snaps off, may get what you want. IF not start a specific thread and tell us what you want to accomplish.
NEXT
Appreciate you prompt reply, Mark! I will try this technique of creating chords.
I was able to rotatecabinets and made it into a block. But once this block is inserted to the current plan, that highlighted cab just turnes back to its original position, it breaks waway from the curved and alignment it was created.
Rotating the object- we found a solution to that, and I use your technique too.
But issue now is why this cab doesn't follow the curvature?
I will try your technique as I wait for your response. Thanks Mark!
