OnlineBuilder2 Posted Sunday at 11:10 AM Share Posted Sunday at 11:10 AM Im trying to raise the bottom floor of this unit complex from 2750 to 3500 and push everything else up. It just make a huge mess of everything. I went into the Defaults and then used the Rebuild Walls etc and tried it manually. Is there a way to do this properly? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Sunday at 04:44 PM Share Posted Sunday at 04:44 PM I will typically check each room and closet to ensure they are actually using the defaults, when this happens Link to comment Share on other sites More sharing options...
GeneDavis Posted Sunday at 06:04 PM Share Posted Sunday at 06:04 PM Start at the top floor, go down. Link to comment Share on other sites More sharing options...
DBCooper Posted Sunday at 08:52 PM Share Posted Sunday at 08:52 PM Assuming that you want everything the same height for each floor level, then all you should need to do is set the default heights for the floors and then use the "reset to defaults" tool (on the main menu under edit) to make sure everything is actually using the defaults. If that doesn't work, then you might want to post the plan. Link to comment Share on other sites More sharing options...
