Ringos Posted December 3, 2024 Share Posted December 3, 2024 In window specification>label I have checked Height/Width Display: Width/Height and Additional Text: Include Schedule Number and Include type. This would seem like I would get 3050DH for width, height, and type and the schedule number. Yet, I only get the schedule number showing on the window. I do not see a schedule number in Active Layer Display options that might be off. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 3, 2024 Share Posted December 3, 2024 The "type" shows ONLY in your "schedule" but NOT in your "label". DJP 1 Link to comment Share on other sites More sharing options...
Ringos Posted December 3, 2024 Author Share Posted December 3, 2024 The question is, how do I get the window type 3050DH and the schedule number to both show in layout? Link to comment Share on other sites More sharing options...
DBCooper Posted December 3, 2024 Share Posted December 3, 2024 You can open up the schedule and check the box for "use both callout and label". 1 1 Link to comment Share on other sites More sharing options...
Ringos Posted December 3, 2024 Author Share Posted December 3, 2024 3 minutes ago, DBCooper said: use both callout and label". How do I open up the schedule? I have it in CAD detail. Link to comment Share on other sites More sharing options...
DBCooper Posted December 3, 2024 Share Posted December 3, 2024 Open the cad detail, click on the schedule, and use the open button. Or find the schedule in the project browser and open it from there. Link to comment Share on other sites More sharing options...
CharlesVolz Posted December 3, 2024 Share Posted December 3, 2024 1 hour ago, DBCooper said: Open the cad detail, click on the schedule, and use the open button. Or find the schedule in the project browser and open it from there. You need to get your referenced plans fixed before you will know what window schedule to fix. Once you are dealing with the correct window schedule, you control what displays here: Link to comment Share on other sites More sharing options...
Ringos Posted December 3, 2024 Author Share Posted December 3, 2024 referenced files fixed CA is working on the window problem. They say it is not acting right. They are happy to help. Link to comment Share on other sites More sharing options...
Solution Ringos Posted December 3, 2024 Author Solution Share Posted December 3, 2024 Solution: If you want to show both the window size (3050) and the schedule number on your plan view and/or layout... 1. Create a cad detail of your window schedule. 2. Go to the project browser and find CAD details under the name of the plan you are working on. 3. Right click and add new cad detail. 4. Go to tools>schedules and select the window schedule. It should show up in the CAD detail. 5. Customize the view of that like you want. 6. This is a great video for that. https://www.chiefarchitect.com/videos/watch/1544/door-window-cabinet-schedules.html?playlist=87 7. Click on the schedule, then open the properties for that schedule. 8. Go to the Label section on the left, then at the top on the right area, select either Both Callout and Label or Label. If that does not work, open the properties for each window you want to show both. Click label and check that width/height is checked. Add a check mark on type if you want it to show the type (DH) of window. If you want both the size and call out to show on the window rather that call out check on the window properties and uncheck callout on the CAD detail. See screenshots below. Link to comment Share on other sites More sharing options...
