davyjones Posted November 8, 2024 Share Posted November 8, 2024 I'm not sure if this an issue with chief terminology or with my understanding, but I can't get the settings correct to replicate the engineering plans I received. Attached is my engineering plan, the settings I used and the result. Any help / tutorials that could guide me in the correct direction? Link to comment Share on other sites More sharing options...
mtldesigns Posted November 8, 2024 Share Posted November 8, 2024 @davyjones Have you tried drawing/modeling a foundation wall with footer (perimeter), then go back in and draw/model another foundation "footer" per say around the inside perimeter? What's this for anyways, kinda unique? I bet you get comments on your name a lot, don't you? Link to comment Share on other sites More sharing options...
scottharris Posted November 8, 2024 Share Posted November 8, 2024 I'm not sure if this is what you are after; I often build slab foundations using a stem wall (wall attached). The brick wall above has a brick ledge that then extends down to the footing. Foundation-Wall.calibz Link to comment Share on other sites More sharing options...
davyjones Posted November 17, 2024 Author Share Posted November 17, 2024 On 11/7/2024 at 8:29 PM, mtldesigns said: @davyjones Have you tried drawing/modeling a foundation wall with footer (perimeter), then go back in and draw/model another foundation "footer" per say around the inside perimeter? What's this for anyways, kinda unique? I bet you get comments on your name a lot, don't you? This is for a home in Oklahoma. I haven't tried any drawings myself, I was hoping chief had something built in. :/ On 11/8/2024 at 7:37 AM, scottharris said: I'm not sure if this is what you are after; I often build slab foundations using a stem wall (wall attached). The brick wall above has a brick ledge that then extends down to the footing. Foundation-Wall.calibz 16.13 kB · 19 downloads I can't seem to open that it says it was made with a newer version. But checking the settings you did, produced some weird results. It looks like I would be unable to use the 'build foundation' option with this, since it would generate a foundation outside the brick? Link to comment Share on other sites More sharing options...
DBCooper Posted November 17, 2024 Share Posted November 17, 2024 Quote I can't seem to open that it says it was made with a newer version. What version are you using? You may not have all the same tools that are in X16 and the ones you do have may work different. Link to comment Share on other sites More sharing options...
