CARMELHILL Posted October 3, 2024 Share Posted October 3, 2024 Anyone else have trouble getting rendered elevations to sync correctly on layout sheets? The lines don't correctly overlay onto the solid fill elevation. I haven't had a chance to do a clean template with all my imported settings yet. This is from an X15 template brought into X16. I noticed this doesn't happen with a new clean layout and plan sheet in X16. Link to comment Share on other sites More sharing options...
MPDesign Posted October 5, 2024 Share Posted October 5, 2024 I have seen this in the past, I delete and resend the view. That usually fixed it. Link to comment Share on other sites More sharing options...
VHampton Posted October 5, 2024 Share Posted October 5, 2024 The refresh viewport tool (to update an elevation) can result in that "ghost" outline. Open the camera view from the viewport, and then close it. Try the refresh elevation option once more. That usually does it. Or... send the camera to layout altogether (as Michael suggested). Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 5, 2024 Share Posted October 5, 2024 i had this a couple days ago and the refresh view did not work. I ended up changing it from plot lines to live and then it worked. but good to know the other options above Link to comment Share on other sites More sharing options...
