AFRAME PORCH
Cadwork22
Do you have an example? Anything is possible.
Not sure if you are asking if the rail can penetrate the roof plane which sounds like the question...
Is it a first floor porch?
Or a second floor covered balcony?
4 hours ago, Cadwork22 said:
Thanks for your response, yes the porch you have marked by the blue arrow, on the side of the gable.  Except in this case there would walls to create a shed below.
I think it would help if you found an example or sketched something to illustrate.  When you say "walls to create a shed below" really threw me.
Build the A Frame roof to cover the living space to the right.
It looks like the roofing covers about half of the footprint.
Use the break roof tools.
  • Start at the base of the roof.
  • Make (2) break points and drag the roof plane up as required (to the 2nd floor ceiling height).
The addition (w/ shed room dormer and roof deck) will be able to merge into the roof new opening.
Sorry, once I get this down, I'll be able to do so down the road.  A few questions, I created a roof opening, however the second-floor juts out. I created a small room/shed; how do you make it even with the roof?  Also, I'll need doors below and above the second floor.  Thank you!
The plan is always a great help in being able to seek assistance.
In getting the roof to work...
Start at the bottom (the roof edge) and use the break roof tools.
By clipping the roof, this clears the way for the 1st and 2nd floor walls.
The ground floor ceiling had to be lowered from 9 feet to 8 feet.  (The shed roof dormer needed head height for the exterior door.)
Anyway, the goal here was to help show how the roof works.  (Floor elevations can be adjusted as necessary.)
Good luck with the project.
(The attached should provide a head start with the basics).
AFRAME3.1.plan
The gable end walls are typically stepped inward from the rake boards.
It's a feature which is common with this style architecture.
Usually constructed in snowy regions, A frame roofing prevents snow loads from piling on.
With regard to the image file... the shed roof pitching back into the house is asking for leaves and tree debris to gather there.
Just saying. It's a water catch unless you put a cricket in between (small peaked roof).
Glad to be of help. That's what we do here.
In terms of the "look", would you mind a couple of observations?
If a reverse gable on the dormer is the direction... perhaps consider making it steep? (the same pitch as the primary roof).
Last observation... This building could be a bit more progressive looking. Modern windows (casements and picture units) would steer the look into something more timeless. There's some really great inspiration in the previously posted links, unless a cabin-like appearance is the goal.
Anyway, All the best.
