Why doesn't Chief autoframe 2x posts between un-mulled windows?
GeneDavis
I drew a test building, placed three windows with 5" space between, a typical arrangement if wanting the post cover (casing between windows) to be a standard 5 1/2" width (one would pec the RO clearance at 1/4" for sides), then autoframed, and got no posts.
If we want the framing to have the posts, we must manually edit to do so.
I was able to get 3 studs with 1/4"-1/2" side rough opening and a 5" space between the windows.  I could not get 1-2 studs to build with larger rough openings even though there was space for them.  Must be some kind of built in limitation.
