GeneDavis Posted September 10, 2024 Share Posted September 10, 2024 I drew a test building, placed three windows with 5" space between, a typical arrangement if wanting the post cover (casing between windows) to be a standard 5 1/2" width (one would pec the RO clearance at 1/4" for sides), then autoframed, and got no posts. If we want the framing to have the posts, we must manually edit to do so. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 10, 2024 Share Posted September 10, 2024 You would need to not mull the windows in order to get framing between them. Mulled windows implies a single manufactured unit, not 3 units. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 10, 2024 Author Share Posted September 10, 2024 See the three labels. They are not mulled. Link to comment Share on other sites More sharing options...
DBCooper Posted September 10, 2024 Share Posted September 10, 2024 I was able to get 3 studs with 1/4"-1/2" side rough opening and a 5" space between the windows. I could not get 1-2 studs to build with larger rough openings even though there was space for them. Must be some kind of built in limitation. Link to comment Share on other sites More sharing options...
