Connelly Posted August 28, 2024 Share Posted August 28, 2024 I am having a problem with haze in ray trace renderings. This is the best result so far, but it is not good. Ray trace method is CPU (only option for the computer). The same haze issue is happening in PBR (no ray trace). Any suggestions on how t get rid o the haze? The darker picture is ray trace. The brighter picture is PBR (no ray trace). Computer is an iMac with an Intel chip. CPU Ray Trace Options -> General: 1024 x 689 pixels, 72 ppi, 30 passes, all other items unchecked. Lighting: Use Automatic Settings, Use Ambient Occlusion min=0.2, max=0.6, Direct sunlight = 2.0, Enable Environment Light = 1.5, Use Color (white), Light Set = Custom light set Image Properties: Use Tone Mapping, Auto Contrast, Intensity=50%, Softness=0%, Color Correction=0%, General Properties Brightness=60%, Contrast=50%, Saturation = 59% Adjust Sunlight: 500 lux, tilt angle -23º, Direction angle 85º Camera Options -> Perspective Full Overview Specification: Show color, Shaow Shadows, Ray Casted Sun Shadows, Reflections, Bloom, Edge Smoothing when Idle, Ambient Occlusion 0%, Use Sunlight, Light Set - Custom light set I have tried changing every setting, and still haze. Tone mapping on = haze, tone mapping off = haze. Occlusion = 0%, 50%, 100%, all have haze. Sunlight at 500 lux to 100,000 lux = haze, enable environmental light from 0.5 to 5.0 = haze. Every parameter has been changed and still haze. -Connelly Link to comment Share on other sites More sharing options...
Gawdzira Posted August 28, 2024 Share Posted August 28, 2024 What is this set to? You might only be using a small number of available interior lights. Link to comment Share on other sites More sharing options...
ericepv Posted August 28, 2024 Share Posted August 28, 2024 Post your plan. Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 28, 2024 Share Posted August 28, 2024 4 hours ago, Connelly said: having a problem with haze in ray trace renderings Haze is almost always caused by using way too bright sunlight. Use PBR and set samples to 50 until you get the result you're looking for. (it's quicker) Here are my PBR settings... This is a screen shot of the result. Took a little less than a minute for the PBR to go through 50 samples. (pretty sad, but that's a Mac for ya) Link to comment Share on other sites More sharing options...
Connelly Posted August 28, 2024 Author Share Posted August 28, 2024 Gawdriza, I have a custom light set that has every light in the kitchen and living room on. Link to comment Share on other sites More sharing options...
Connelly Posted August 28, 2024 Author Share Posted August 28, 2024 Michael, I am on a Mac with an Intel CPU and no graphics card. PBR is not ray tracing on my computer. also, I have set sunlight all the way down to 1 lux. It makes no difference. Link to comment Share on other sites More sharing options...
Connelly Posted August 28, 2024 Author Share Posted August 28, 2024 Eric, plan is 57mb. It's a bit beyond the 14mb limit. Link to comment Share on other sites More sharing options...
ericepv Posted August 28, 2024 Share Posted August 28, 2024 2 minutes ago, Connelly said: Eric, plan is 57mb. It's a bit beyond the 14mb limit. Can you ZIp it? Link to comment Share on other sites More sharing options...
Gawdzira Posted August 28, 2024 Share Posted August 28, 2024 Having the lights on does not mean the camera will use them. That DBX I posted is from the camera that you are using. The default number of lights is lower than the 80 I am showing. If it is at the default, the lights in your kitchen may not be used in the render even though they are set to ON. Link to comment Share on other sites More sharing options...
