Gable Roof Over Window
builtright3
Joey since I am one that does 90% or better of my roofs manually I would do it that way, you can do it auto if you set the room wall heights so this migh mean putting in an invisible wall to get the different fascia or baseline heights and adjust from there by selecting each room
The other way I would do it without the invisible wall would be to adjust the ceiling height for the right side and put the roof on it the go back and put the room ceiling to default height and put the left pitch on and adjust roof heights and pitch from there
I ended up putting in two interior walls perpendicular to the exterior wall spacing them 4' on each side of the window center to give me a base line for the start of the roof and drew in a manual roof and then deleted the interior walls I used after It was complete. Also I used the "Join Roof Planes" even though I had two different pitches. Took me about 20 minutes and worked like a champ. Thanks for the ideas!
